Author Topic: Omega Elite 1997 ECU...  (Read 3594 times)
oredona
  • chatham, Kent
Re: Omega Elite 1997 ECU...
« Reply #15 on: 04 December 2007, 11:31:02 »
Did you plug the idle valve back in?
Try starting it with a little throttle....
question: I don't know if i took such out in the first place, how does it look like?...i did not go to the engine, only inside the car.
Thanks
« Reply #16 on: 04 December 2007, 11:38:11 »
You said you changed the crank sensor 3 days before and this normlay requires removal of the plenum (but can be done without), if the idle valve connector (right side of plenum) was not clicked fully home on re-fitting, it could be the cause.
Hence why I sudgested trying it with a little throttle as this gets round the need for the idle valve when cranking.
