Author Topic: ABS Control Unit  (Read 4987 times)
Markjay
  • London
Re: ABS Control Unit
« Reply #15 on: 06 December 2007, 23:03:07 »
...Can't remember if a cheapo Tech 2 will read the ABS/TC codes but I have one (in Alton, so not too far away) if you want to try. Failing that a visit to TheBoy might be in order.
Cheapo Tech2 has ABS/TC on the menu, but not all menu options work (apparently different options work on different cars...) so in theory the answer is yes, in practice it is pot luck...
Alas, no more Omegas....
« Reply #16 on: 07 December 2007, 12:18:18 »
The version I run does (custom)......but then it has most of the fault code sets behind it.
« Reply #17 on: 07 December 2007, 12:58:43 »
Jaime, you rekoned my ABS sensor had gone?
I don't get the light on, just a dogey speedo reading.... used to flip up and down erratically. Now its just dead. Along with dogey speed assist steering.
if you have cruise control has that packed up as well?
I know when mine went i had all the symptoms you describe, but the ABS & TC light was on
That what confuses me, no abs and tc lights for me, cruise still works! Just no power asssit steering and no/dogey speedo reading.
Why i suspected speed sensor on the autobox.
« Reply #18 on: 07 December 2007, 13:25:12 »
Suspect what you like....you would be wrong in this case.
Autobox speed sensor connects to the autobox only.......and I guess the autobox is working fine.
Have you checked the cabin fuses, is the speed dependent volume working on the radio, what about the average speed on the MID?
« Last Edit: 07 December 2007, 13:34:52 by Mark »
« Reply #19 on: 07 December 2007, 13:56:34 »
lol the car will barely make it off the drive with the gearbox, it wines and screeches. Need to get it replaced. Not driven it in ages so can't remember
