Author Topic: CUTTING OUT WHEN CHANGING GEARS(HELP)  (Read 5462 times)
dartsace
« on: 17 August 2006, 16:21:10 »
 :'(please can anyone help me,im not only new here but owning an omega 2.5td gls is as well.
when im driving and then change gear it just goes dead and i dont move,its not stalling but when it happens i have to take foot right off accelerater then re press then it goes again,this is ruining my appreciation for this car as it was recommended but unable to enjoy as yet please please HELP.
Re: CUTTING OUT WHEN CHANGING GEARS(HELP)
« Reply #1 on: 17 August 2006, 16:23:56 »
Welcome :D
Sounds like its an electrical/electronic problem. Could be TPS (throttle position sensor) or not sure if TD has a Clutch switch which could be a problem.
One of the TD guys will no doubt know more...
nixoro
  • Hitchin, Herts
« Reply #2 on: 17 August 2006, 16:39:43 »
Welcome to the site dartsace  :)
Is yours an auto or a manual?
dartsace
« Reply #3 on: 17 August 2006, 16:44:10 »
THANKS ITS A MANUAL
« Reply #4 on: 17 August 2006, 16:44:57 »
Plus, what year is it and does it pull OK when accelerating?
Who recommended the 2.5TD?
nixoro
  • Hitchin, Herts
« Reply #5 on: 17 August 2006, 16:55:54 »
Could be a case of the clutch not picking up, perhaps slipping like mine did.
dartsace
« Reply #6 on: 17 August 2006, 16:57:18 »
THANK YOU ALL FOR YOUR WELCOME AND HELP,COULD IT BE ECU  :'(IM NOT MUCH GOOD WITH MECHANICS ETC
nixoro
  • Hitchin, Herts
« Reply #7 on: 17 August 2006, 16:59:28 »
If it was ECU related by rights you would have the EML on, the orange light with a picture of an engine with a slash through it I think its the same on both petrol or diesel.
dartsace
« Reply #8 on: 17 August 2006, 17:01:54 »
SORRY ITS A V REG,ALSO CANT FIND HAYNES MANUAL FOR IT.IT DOES PULL OFF SLOW UNLESS YOU PUT FOOT RIGHT DOWN
« Reply #9 on: 17 August 2006, 17:02:09 »
So, when you change gear and release the clutch does the engine revs increase but the car doesn't accelerate or do the revs stay low?
dartsace
« Reply #10 on: 17 August 2006, 17:06:05 »
THEY STAY LOW
nixoro
  • Hitchin, Herts
« Reply #11 on: 17 August 2006, 17:06:51 »
Im guessing yours is border line between pre facelift or is a facelift, from what I can tell the haynes you can get only goes upto T reg so if facelift they didn't create one.
« Reply #12 on: 17 August 2006, 17:23:47 »
Are the brakes ok, plenty of assistance?
I'm thinking either blocked fuel filter or fuel tank pick-up.
Vaccum fault.....(hence the above question)
Or even a main air inlet pipe dislodged (check the turbo on the drivers side bottom of the engine bay), where did you buy it form?
dartsace
« Reply #13 on: 17 August 2006, 17:35:27 »
thanks for all your help,i will try to check all suggestions asap.i got it private from a place called  chipping campden in warwickshire.
busastars
  • Gwent
« Reply #14 on: 29 October 2007, 00:31:26 »
Another one that has similar problem's as mine. Anyone know what it could be, just getting desperate now as I need the car sorted this week.
Thanks
