Author Topic: Crank sensor  (Read 10715 times)
Pride and Joy
  • Bridlington E. Yorks
Crank sensor
« on: 21 November 2007, 16:17:37 »
Having a problem with starting my pride and joy. Usually occurs after a short stop. Get the emissions/exhaust icon up on the dash - goes out after a few more starts. After reading several issues in this excellent forum I'm thinking on the lines of the crank sensor. Can you please advise on location etc and proceedure for the change of. Here's hoping that it is a quick and easy job as I will be doing it in the drive - Brrrrrr cold out there now!!!
Thanks for your help, in advance, guys.
Regards Peter
Re: Crank sensor
« Reply #1 on: 21 November 2007, 16:19:33 »
Get the codes read....I am suspecting possibly cam sensor (given that its a 2.2!)
Pride and Joy
Re: Crank sensor
« Reply #2 on: 21 November 2007, 17:06:27 »
Code 0340, according to my pet mech, this was from memory from the last time I had the prob. Couldn't do a recheck today as he has lent it out to a friend. If this is then correct can you please advise on the changing of the same.
Thanks all for your help
Regards Peter
Re: Crank sensor
« Reply #3 on: 21 November 2007, 17:21:37 »
0340 is indeed cam sensor......
Pride and Joy
Re: Crank sensor
« Reply #4 on: 21 November 2007, 18:10:09 »
Have ordered the animal - will arrive on Friday. аг50 + vat - ouch!
All tips and advice most welcome on doing the job!
Regards Peter
Re: Crank sensor
« Reply #5 on: 21 November 2007, 18:20:10 »
Its a nice easy job on the 2.2 :)
Pride and Joy
Re: Crank sensor
« Reply #6 on: 21 November 2007, 18:31:06 »
Sounds good - where is it. Does the cam cover need to come off. Got the gasket and o rings just in case
« Last Edit: 21 November 2007, 18:33:10 by Pride_and_Joy »
Regards Peter
Re: Crank sensor
« Reply #7 on: 21 November 2007, 18:31:44 »
Sounds good - where is it. Do the cam covers need to come off. Got the gaskets and o rings just in case
nope
Pride and Joy
Re: Crank sensor
« Reply #8 on: 21 November 2007, 19:59:50 »
Great - really helpful and costructive advice.
Many Thanks
Regards Peter
Re: Crank sensor
« Reply #9 on: 21 November 2007, 20:31:46 »
Cambelt cover, IIRC, needs to come off to get to the screw, so aux belt needs to come off...
« Last Edit: 21 November 2007, 20:32:14 by TheBoy »
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Crank sensor
« Reply #10 on: 21 November 2007, 20:37:30 »
Correct.
I like red cars
Re: Crank sensor
« Reply #11 on: 21 November 2007, 22:16:42 »
Yep, aux belt off, cambelt cover off and spark plug cover off....remove the torx bolt between the two cam sprockets and pull the sensor up and out from the end of the cam cover spark plug recess......re-fit is reverse of removal.
Re: Crank sensor
« Reply #12 on: 21 November 2007, 22:25:06 »
Occasionally with a new length of loom...
Pride and Joy
Re: Crank sensor
« Reply #13 on: 22 November 2007, 06:42:03 »
Cheers guys - will have a go at the weekend - weather being good!
Regards Peter
Pride and Joy
Re: Crank sensor
« Reply #14 on: 28 November 2007, 09:02:23 »
URGENT - got it all stripped down - sensor will not come out - seems to be caught behind the cam sprockets - help please
Regards Peter
