Author Topic: crank sensor?  (Read 1660 times)
big_bopper
  • Worksop
  FOOK A DUCK !!!!
http://www.rebelvanners.co.uk/
magnul
  • Trondheim, Norway
Re: crank sensor?
« Reply #1 on: 09 December 2007, 21:05:17 »
You'll have to check the connector. The 90458251 one is for early models where the female connector is an integral part of the duct containing a zillion wires including the injector connectors. I believe newer cars have a separate connector for the crank sensor that is easier to disconnect. Also think that the 90458251one has 3 pins wheras the other one has 4.
big_bopper
  • Worksop
Re: crank sensor?
« Reply #2 on: 10 December 2007, 10:19:07 »
thank you, oh well looks like another trip to mega expencive Vauxhalls then :(
  FOOK A DUCK !!!!
magnul
  • Trondheim, Norway
Re: crank sensor?
« Reply #3 on: 10 December 2007, 10:32:35 »
No need to. You fix it yourself. My car is of the old type and have the connector here:
Just follow the wire along the cambelt cover and see where it ends up. There is also a difference between the two sensors in the business end as you can see from the ebay pics. It should be possible to find out from chassis or engine# which sensor you need.
Re: crank sensor?
« Reply #4 on: 10 December 2007, 11:10:08 »
2.0 16v to 14194716 - 90458251 £54.50 + Vat retail
2.0 16v from 14194717/31000001 - 9174621 (£=less than the above)
big_bopper
  • Worksop
Re: crank sensor?
« Reply #5 on: 10 December 2007, 15:13:46 »
have done a begging call to Vauxhalls and have given them my chassis number and they have told me that the sensor i need is a 9174621 which would be EBay item
http://cgi.ebay.co.uk/VAUXHALL-CRANKSHAFT-SENSOR-CRANK-ASTRA-OMEGA-VECTRA_W0QQitemZ150191856295QQihZ005QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
mega amounts cheaper
  FOOK A DUCK !!!!
