Author Topic: ABS/TC fault -2.5V6cd-1999 (V)  (Read 1844 times)
Jazzer
  • Dumfries
« on: 12 December 2007, 00:35:17 »
I have just bought the above having been a Senny man before.
(1) The ABS &TC warning lights are permanently on and
(2) the speedo does not work.
(1) Will it be a sensor(s) needs replacing.
(2) Will it be the head unit that needs replacing and if so has anybody got one.
Jazzer
« Last Edit: 12 December 2007, 00:44:48 by hotel21 »
hotel21
  • The Kingdom of Fife
Re: 2.5V6cd - 1999 (V)
« Reply #1 on: 12 December 2007, 00:43:31 »
Probably a sensor fault.....
All operated from Hall effect sensors either side of the diff, ajacent to the gear tooth type sensors on the driveshafts....  check all electrical connections down there in the first place, then we can collectively take it from there....
« Reply #2 on: 12 December 2007, 00:44:29 »
Jazzer
Your speedo ABS & TC all use the ABS for their speed references. Sounds like it could be the ABS unit that's fubar'd, if you search the site you'll find details of where you can get your unit refurb'd as a new one will cost you the same as your car did.  :(
Buy your Senator back!  :y
« Last Edit: 12 December 2007, 00:45:07 by Andy_B »
Jazzer
  • Dumfries
Re: ABS/TC fault -2.5V6cd-1999 (V)
« Reply #3 on: 12 December 2007, 09:20:17 »
Thank you for that joyous news! I will pursue the refurb.advice.
« Reply #4 on: 12 December 2007, 10:14:19 »
As I've said before .. I rate BBA Re-man very highly, they sorted my identical problem - fubarred ABS ECU - very fast and at a decent cost compared to Vx
Give them a ring on 01634 230 055
I have no link to them other than as a highly satisfied customer  :)
« Last Edit: 12 December 2007, 10:15:02 by entwood »
« Reply #5 on: 12 December 2007, 10:19:53 »
I also rate Peacock and Purvey (in derbyshire) who I now see are advertising on ebay.
http://cgi.ebay.co.uk/Vauxhall-Vectra-Omega-ABS-Pump-ECU-Modulator-Module_W0QQitemZ150193942705QQihZ005QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
With a 2 year warranty!
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 12 December 2007, 18:40:20 »
Check the sensors first though!
Jazzer
  • Dumfries
« Reply #7 on: 12 December 2007, 20:56:22 »
Thanks for all advice so far! :)
Jazzer
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #8 on: 12 December 2007, 22:30:47 »
yep, sounds like ABS ecu has gone faulty.
You would have lost Cruise control as well al of this is linked in with the ABS.
the companies that the guys are talking about will be able to help, the only other thing you may need to do is to recode the ECU to the car, it depends if they recon yours or not
Jazzer
  • Dumfries
« Reply #9 on: 13 December 2007, 00:28:41 »
Thanks, Sir Jay W. :)
