Author Topic: Confused over headlights  (Read 2095 times)
razzo
  • Crapital
    • 97 3.0 Elite
« on: 14 December 2007, 18:53:13 »
As i understand it 97 Omegas did not come with HID's fitted as standard & it is difficult to retro fit as there is no level sensor on suspension arms. My Elite had ribbed headlights  & been upgraded to projectors which is a good improvement. I think TB said if the chassis No. has a V at the end then it is not HID but if its a W then HID's fitted as standard. Went to WIM today & as it was up on ramps, noticed it had a level sensor on the rear driver side suspension arm & it has washers fitted, so is this the norm & can i fit HID's, any advice?
     Cheers Steve
hotel21
  • The Kingdom of Fife
Re: Confused over headlights
« Reply #1 on: 14 December 2007, 19:00:09 »
Level sensors for HID are on the FNS and RNS suspension arms.  The sensor on the ROS is for adjustable rear suspension....
HID fitted cars do not have a headlamp level adjuster wheel to the left of the headlamp on/off switch.
(Check here - http://www.omegaowners.com/forum/YaBB.pl?num=1189080951 - must really finish this sometime!!)
« Last Edit: 14 December 2007, 19:02:01 by hotel21 »
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 14 December 2007, 19:10:35 »
Thanks  :y
Page created in 0.009 seconds with 20 queries.
