Author Topic: ECU fault codes  (Read 1629 times)
mykd2007
  • Essex
ECU fault codes
« on: 15 December 2007, 16:33:04 »
Hi,
I have just done the paperclip test on My 3.0 V6. It has come up with 38. Could you tell me what 38 is please.
Thanks,
Myk
Fast & Cheap is not reliable. Cheap & Reliable is not fast. Fast & Reliable is not cheap!!
magnul
  • Trondheim, Norway
Re: ECU fault codes
« Reply #1 on: 15 December 2007, 16:47:36 »
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
38   O2 Sensor 1 Circuit Voltage Low
mykd2007
  • Essex
Re: ECU fault codes
« Reply #2 on: 15 December 2007, 16:49:21 »
Thanks for the quick reply. I take it this would be the lambda sensor on the exhaust?
magnul
  • Trondheim, Norway
Re: ECU fault codes
« Reply #3 on: 15 December 2007, 17:27:04 »
Yes, but as you have a V6 you have two. The code is on sensor bank 1, but I don't know which one that is. It's per definition the bank with cyl#one.
