Author Topic: Power steering pump leak  (Read 2073 times)
Mike Collins
  • North of Bristol
« on: 27 November 2007, 20:46:01 »
Does anyone have any experience of leaking hydraulic pumps? My 2.5 has started to drop red fluid from the front of the block.
Fluid level is probably going down, but a bit early to be certain.
There is no sign of a leak from the pump spindle, only on the block face, it drips down and is then blown back along the sump pan. I can see no evidence of leakage from any of the pipes or unions.
Otherwise anyone like to sell a pump?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Power steering pump leak
« Reply #1 on: 27 November 2007, 20:48:29 »
Have you checked the jubilee clips are nice and tight?
Mike Collins
  • North of Bristol
« Reply #2 on: 27 November 2007, 21:25:54 »
Look ok, no sign of fluid leakage down the pipes, only at the back of the pump.
So far.....
Mike Collins
  • North of Bristol
« Reply #3 on: 15 December 2007, 17:36:46 »
Update on steering fluid leak, replaced the suction hose and clips, now leaking badly.
It appears to be from the rear of the pump, only under load at a high rate.
I have removed and inspected the pump, the A/C compressor does not need to come off despite TIS.
Now refitted and still leaking, I can only guess the rear face has a bad seal.
Anyone have a 98 2.5 pump for sale?
