Author Topic: Paperclip test  code 16  (Read 1250 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 16 December 2007, 12:12:54 »
A few weeks back I did paperclip test, posted results and thought I had cured it with a different Throttle position sensor.
had a least 20 clean starts so any stored codes should have gone from that problem.
Yesterday the EMl came on and stayed for about five mins before staying off since.
The code is 16 . Any suggestions or ideas welcomed?
varche
Bandit127
Re: Paperclip test  code 16
« Reply #1 on: 16 December 2007, 13:09:03 »
There's a post just above yours (until I post this..) with the same error. For general reference, Mark's list of codes for the V6 is in the FAQ section.
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
Jim
« Reply #2 on: 16 December 2007, 14:37:01 »
knock sensor, check for trapped lead....
« Reply #3 on: 16 December 2007, 18:59:50 »
Knock sensor number 1....which is the air filter side....
Check for trapped wires or a poorly routed wire which is being caught by the aux belt.
