Author Topic: Power steering switching off....and on....then off  (Read 1750 times)
mykd2007
  • Essex
« on: 15 December 2007, 16:15:35 »
I have a problem with the power steering on mine. I can guarantee that when I want to park, it will have switched itself off, and a bit later, when I have got used to having to heave it round roundabouts etc, it will switch back on (which can be 'Very' interesting if I'm not ready for it!, as I end up with the nose pointing toward the roundabout with the tail coming sideways.....).
Any ideas? (I have tried the obvious, pulley belt tension and fluid levels).
Thanks
Fast & Cheap is not reliable. Cheap & Reliable is not fast. Fast & Reliable is not cheap!!
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Power steering switching off....and on....then
« Reply #1 on: 15 December 2007, 17:12:34 »
I think the Elite steering can be adjusted with a TechII, you really need to have the codes read.
I like red cars
mykd2007
  • Essex
« Reply #2 on: 15 December 2007, 17:23:42 »
I did paperclip it, and the only code was 38 for the O2 sensor.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 15 December 2007, 17:34:41 »
Don't think you can read the power steering module with the paper clip test, needs to be TechII'd.
I like red cars
« Reply #4 on: 15 December 2007, 20:32:04 »
You cant read the power steering codes with a paper clip.
Check the fuse is ok.....I ahve seen some go intermittent.
Is the speedo etc all working ok?
mykd2007
  • Essex
« Reply #5 on: 16 December 2007, 08:02:44 »
The speedo works fine, I will check the fuse today.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #6 on: 16 December 2007, 20:46:52 »
If the fuse has blown with the power steering on a pre-facelift (not sure if the same on facelift model I have now) then the cigarette lighter socket will be faulty too. They run on the same circuit.
I had a dodgy cigarette lighter that occasionally blew the fuse. This would also take out the power steering.
« Reply #7 on: 16 December 2007, 21:05:49 »
What year is the car?
Page created in 0.029 seconds with 20 queries.
