Author Topic: Facelift Hazard Switch - removal, where to buy  (Read 1990 times)
unclelicklug
  • Sheffield
« on: 18 December 2007, 08:30:03 »
Following on from my post yesterday - thanks guys, assuming I need to replace the switch does it just pull out, and is there a good supplier?
Thanks again
Rick
Re: Facelift Hazard Switch - removal, where to buy
« Reply #1 on: 18 December 2007, 09:53:20 »
Whole button or just the front? front can be replaced easy.
i replaced mine cause the button was starting to peel.
I got a replacement from a scrapyard.... freebie  :-X
Insert a flat head screw driver on the right hand side (drivers side) there should be a little slot to get a screw driver in there, just ping it out. and push the new cover on.
unclelicklug
  • Sheffield
« Reply #2 on: 18 December 2007, 10:00:36 »
Thanks - I think it will have to be the whole thing as it seems to be stopping my indicators working!
« Reply #3 on: 18 December 2007, 10:02:19 »
Once the front section is off, remvoal is fairly obvious (from memory).
There not that pricey from the dealers....
