Author Topic: Spark Plug Wells  (Read 2297 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Spark Plug Wells
« on: 18 December 2007, 14:11:03 »
When the weather was a bit warmer i thought i'd change the spark plugs on the mig, so without any manuals or 'owt i went for the black strip with ecotec written on it, but on lifting it i could see pools of oil, so i put it back thinking 'oops wrong place'. :o
Just read the facelift 2.2 plug change guide and i WAS in the right place... :P
So... the oil?? rocker cover gasket?? would explain the very occasional misfire (although only does that on LPG).
Comments???
(apart from i can't believe you didn't know where the plugs were, you plank) ::)
Omega 2.6 V6 Elite in Shiny Black
Re: Spark Plug Wells
« Reply #1 on: 18 December 2007, 14:13:39 »
when you say pools was it really a lot, across all 4 plugs??
Its not uncommon to get oil in plugs 2/3, because they are around the oil filler bit, its easy when filling to miss and for it to drip down into the wells.
mark.adams
  • Cambridgeshire
  • Happy
« Reply #2 on: 18 December 2007, 14:51:11 »
well i lifted the black bit up and the rubbery bits that protrude downwards looked like they were dipped in oil.
 ;Dtechnical i know... ;D
« Reply #3 on: 18 December 2007, 15:48:42 »
cam cover gasket needs changing. Don't miss the O rings too. Nice easy job. Change the coil pack too if it looks iffy (I believe you can get the rubber ends, alternatively).
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 18 December 2007, 15:53:02 »
Thank you
Would that explain the oil leak i wonder....?
« Reply #5 on: 18 December 2007, 16:00:46 »
Thank you
Definately :)
mark.adams
  • Cambridgeshire
  • Happy
« Reply #6 on: 18 December 2007, 16:08:37 »
So...
shopping list for January...
Coil Pack (maybe)
Cam Cover Gasket
Spark Plugs (already Got those)
What breathers should i make sure aren't blocked to prevent gasket being blown again?
Danny
  • Wigan, Greater Manchester
« Reply #7 on: 18 December 2007, 16:25:36 »
So...
Coil Pack (maybe)
Cam Cover Gasket
all of them, to be on the safe side :D
mine had this problem last month, FULL of oil, surprised it hadnt affected it's running... fixed now
Grumpy
  • Manchester
« Reply #8 on: 18 December 2007, 16:45:19 »
'Auto Addict' has done a good guide for the 2.2 breathers.
http://www.omegaowners.com/forum/YaBB.pl?num=1162397695
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #9 on: 18 December 2007, 19:49:33 »
Comments???
<<<<<<< You Clown ;D ;D ;D
