Author Topic: LSD , what are they fitted to..  (Read 7254 times)
pugtop
  • The comfy chair , not THE comfy chair!
Re: LSD , what are they fitted to..
« Reply #15 on: 17 December 2007, 20:16:12 »
Like T/C , I find ABS can be annoying on my works Transit , that really needs T/C though .....are there many LSDs around 2nd hand in the uk?
Too many Peugeots , not enough comfort!
106rallye
  • Glasgow
« Reply #16 on: 18 December 2007, 13:45:14 »
Cool , i'm after an MV6 , seen a couple but not really had the chance to give them the'BEANS' if you know what I mean. The Auto one I drove had Traction Control though??? I have a Quaife LSD fitted to my 205 GTi Rally car and it totally changes the way it drives , much more traction on wet surfaces..
ha ha if anything the LSD give me less traction in the wet as its sideways at every corner. It does make the driving alot more interesting though. I wouldnt of considered buying an omega if it didnt come with one.
sideways is the way forward!
« Reply #17 on: 18 December 2007, 14:31:19 »
He He. I think the Westfield was on opposite lock for about 100 yds this morning after turning out of my road. Not so much ice as too much salt on the road. I suspect my viscous coupled LSD is a little too viscous at -3 degrees!
Paul M
  • Edinburgh
« Reply #18 on: 18 December 2007, 14:35:57 »
Spare a thought for my task coming on Friday -- I left my car at my folks' house last weekend (well actually all 3 of them lol) in anticipation of taking the bike down there on Friday to park it up for the winter. Long overdue I know. What I didn't anticipate was the weather hovering just above freezing all week, not exactly ideal conditions for a 70 mile ride on an R1 with semi-race tyres :o I'll just have to try my utmost to ride like a pussy, easier said than done!
Paul M
  • Edinburgh
« Reply #19 on: 18 December 2007, 14:36:52 »
BTW forgot to add, my MV6 doesn't have a slipper even though it's a manual, so it seems they're pretty unusual on retail models.
Craig_Rogers
  • Redditch
« Reply #20 on: 18 December 2007, 18:22:40 »
Best way to find if you have an LSD (apart from looking at the stamp, there is an identifier, can't remember what) is park up with one of the wheels on a grassy/muddy verge.
Pull off quickly, if you don't move very fast and start spitting grass and mud everywhere then you ain't got and LSD.
Also, if I remember correctly..........  Jack the back up, put it in gear and spin one of the wheels by hand.  If the opposite wheel turns in the opposite direction it's not an LSD, if it spins in the same direction it's an LSD.  Anybody back me up on that?????
Craig Rogers
pugtop
« Reply #21 on: 18 December 2007, 19:16:45 »
Yeah that rule works for front wheel drive LSDs too... My 205 GTi Rally car has a Quaife LSD as said before , jack the front up , spin one wheel , the other spins in the same direction , my other 205 however doesn't have one and the wheels spin in opposite directions.
psnimv6
  • tyrone n ireland
« Reply #22 on: 18 December 2007, 21:18:25 »
thats not the case in the omega because mine has a slip diff and if you jack it up and spin the wheel one way the other spins the opposite  direction, i know in fords the slip diff does what you said but the omega has a different type of slip diff so this does not identify a slip diff hth
Paul M
  • Edinburgh
« Reply #23 on: 18 December 2007, 22:30:27 »
The quaiffe is a torque sensing diff, similar to the Torsen centre diff used by proper Audi quattros (not the Haldex rubbish used in the A3 and TT). The Omega one is a viscous coupling, so it acts like a normal diff until there is enough slip to lock up the coupling, hence it will behave like a normal diff when turned slowly.
« Reply #24 on: 18 December 2007, 22:36:27 »
I thought a viscous diff would behave as described but torsen and plate diffs behave as an open diff until enough torque is applied for it to lock. With the ex-Granada Cosworth diff in my Westfield (viscous) it's only just possible to turn one of the rear wheels by hand while holding the other one still. The certainly want to rotate together  :-/
A viscous diff will feel like an open diff if it's past it ;)
106rallye
  • Glasgow
« Reply #25 on: 19 December 2007, 13:00:36 »
the omega is a plate diff, not viscous (well mine is anyway).
The best way to check if its got a working diff and a way that has NEVER failed me is.
stop, engage 1st, brake with your toe, accelerate with your heel and side step the clutch, slowley lift brake, pull away, look behind and it there is 2 black lines then its got a diff  ;D (this will also test if the cluch has much meat left on it  ;) lol)
