Author Topic: engine splutter!!!  (Read 2260 times)
garyv6
  • sunderland
engine splutter!!!
« on: 19 December 2007, 19:41:21 »
hello all! all of a sudden when i pull away my omega has started to loose power and splutters till i get some speed up! it also does it when the engine is warmed up?? it dont sound healthy at all any ideas please!
merry xmas everyone ;)
gary
Martin_1962
Re: engine splutter!!!
« Reply #1 on: 19 December 2007, 20:50:26 »
Clean your breathers, and check if your EGR valve or your ICV are jamming
« Reply #2 on: 19 December 2007, 20:54:28 »
Daft question I suspect ... but are you "flooring" it on damp surfaces ??  If you are it may just be the Traction Control cutting in ... if it is you should get a flashing TC light on the dash.
Try accelerating a tad slower... gentle with the right boot !!.... and see if this sorts it  :)
« Reply #3 on: 19 December 2007, 21:06:52 »
gary
dont you get any EML light ?
garyv6
  • sunderland
« Reply #4 on: 19 December 2007, 23:13:38 »
theres no lights on dash and i dont floor it! its still the same with the t/c turned off! when im in park and i rev it up it sputters till i get the revs pretty high! i hate it when cars break!!! :( :'( >:(
« Reply #5 on: 19 December 2007, 23:21:18 »
Could be a misfire = check for oil in plug wells, change plugs, and check leads.
Also check for fault codes..
