Author Topic: 3 Fault Codes  (Read 1254 times)
Craig_Rogers
  • Redditch
3 Fault Codes
« on: 22 December 2007, 13:35:55 »
OK, maybe ignoring my previous post about the coil pack mounting bolts........
Maybe this is why I struggles to start when it's cold......
The car has 3 fault codes logged;
135 - That's the actual check lamp itself, it's warning of low voltage
57 - Idle Speed Control Valve Intruption
73 - Air Flow Sensor Low Voltage
Anybody got any ideas as to why suddenly all these are showing.  There where no faults originally, before I changed the coil pack.   Maybe i've upset the loom somewhere????
Thanks in advance!
Craig Rogers
Re: 3 Fault Codes
« Reply #1 on: 22 December 2007, 13:49:34 »
Check for air leaks, are all the pipes connected properly including the brake servo hose (commnhly missed the first time)......the codes point towards an air leak.
I assume the connector to the idle valve has been re-fitted?
Craig_Rogers
  • Redditch
Re: 3 Fault Codes
« Reply #2 on: 22 December 2007, 13:52:55 »
Hmmmm, maybe!   There are a hell of a lot of pipes around the back there, I'll take a look!
Thanks!
Craig Rogers
