Author Topic: LPG - I've got problems.  (Read 9010 times)
« on: 20 December 2007, 13:13:09 »
Idle on LPG is now crap, it hunts all over the place, and stalls upon stopping. Even at full temp.
I'm driving around everywhere on petrol now.
The Evap is lovely and hot, and no obvious software issues. Please Help  :'(
Martin_1962
Re: LPG - I've got problems.
« Reply #1 on: 20 December 2007, 13:21:39 »
Mine was not drivable until warm.
So I let it idle on gaas for about 10 minutes to thoroughly warm up.
Very cold air is denser, so try richening the mixture slightly.
What temperature is the vapour hose?
chrisdb
  • Chesterfield
« Reply #2 on: 20 December 2007, 13:23:27 »
James, could you have a blocked filter?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
« Reply #3 on: 20 December 2007, 13:25:15 »
Thanks for all the replies.
The hoses are all red hot, and so is the evap.
Even when fully up to temperature, it idles really rough on gas.
Through the rev range is fine... and filter is new.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #4 on: 20 December 2007, 13:33:26 »
when mine forst goes over to gas it does faulter a lot for about 20-30 seconds, from there is it fine.......
i would try and richen the mix slightly, try moving the whole map up a point or two and see if that helps
« Reply #5 on: 20 December 2007, 13:39:26 »
Tried that, no joy ;)
« Reply #6 on: 20 December 2007, 13:49:58 »
the only reason coming to my mind is MAF.  because the changing parameter can only be air in the mixture,
 if one the LPG equipment parts didnt go foobar..
« Reply #7 on: 20 December 2007, 13:54:46 »
That would also cause bad idle on petrol, though...
« Reply #8 on: 20 December 2007, 14:15:41 »
old carburator systems never had problems with LPG in very cold weather (-15 Celcius ) ..I remember even the car in the morning start more easy with LPG then petrol..
As I remember we generally block the air entrance half with bandage..Can you try that ?
I think the main difference between those systems is the ECU arranging the amount of fuel injected according to air flow measured through MAF..
Martin_1962
« Reply #9 on: 20 December 2007, 14:16:27 »
Check your plugs
« Reply #10 on: 20 December 2007, 14:24:13 »
i've done that as well, the plugs are new  :'(
« Reply #11 on: 20 December 2007, 15:50:45 »
Bigger/better evaporator?
« Reply #12 on: 20 December 2007, 15:51:25 »
what effect would clamping the vac pipe have? Should I give this a go and see if idle smooths out?
Martin_1962
« Reply #13 on: 20 December 2007, 16:59:24 »
Stop it increasing output when throttle is pushed
« Reply #14 on: 20 December 2007, 17:34:43 »
What is the vapour pressure doing? If that's stable I'd say the vapouriser is OK.
Can you cut individual cylinders and see if one or two are playing up or the whole lot?
Pages: [1] 2 3 4  All   Go Up
