Author Topic: Fitting cruise control  (Read 4706 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 21 December 2007, 12:35:06 »
Well i got my new stalk and fitted it as per the excellent instructions on here :y, just needs the tech 2 thing done (after xmas) to enable.
Only problem now is the new stalk has bright white writing on it and the original LH talk has faded writing :P, i may have to change that one too so they match... its never ending..... ;D
Omega 2.6 V6 Elite in Shiny Black
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Fitting cruise control
« Reply #1 on: 21 December 2007, 12:37:16 »
Mark, have you tried the cruise out? Some members have found that it is already enabled and didn't need to be Tech2'd. I wasn't that lucky but you never know.  :y
[size=24]        [/size][/b]
mark.adams
  • Cambridgeshire
  • Happy
« Reply #2 on: 21 December 2007, 12:43:52 »
Actually i haven't, i presumed it wouldn't be enabled, over what speed can it kick in?
« Reply #3 on: 21 December 2007, 12:45:18 »
About 20MPH I think.
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 21 December 2007, 12:48:12 »
Right going out for a spin now, i'll post back in 5 mins ;D
Fingers crossed :y
mark.adams
  • Cambridgeshire
  • Happy
« Reply #5 on: 21 December 2007, 13:01:25 »
Unfortunately... its not enabled already..
The strangest thing just happened. Started the car, spanner light came on, flicked over to LPG, it went off, drove off.
I thought i'd thrash it in sports mode down to the roundabout except the car wouldn't go over 4000 revs, pulled over, turned off and restarted and it was fine. Bloody vauxhalls.... ;D
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #6 on: 21 December 2007, 13:03:28 »
mine was pre enabled and i grinned like an idiot after paying 10£ and fitting it there and then  hope yours is too ;)
dieseldonicely
« Reply #7 on: 21 December 2007, 22:56:43 »
Yet to see an Omega DBW petrol with it preenabled.  If you get over my way, I suspect I am cheaper than any business for enabling.  If yours is a manual, you may need a clutch switch...
dpanic88
  • West Midlands
« Reply #8 on: 23 December 2007, 12:44:44 »
Re: TheBoy - you might need a clutch switch.
If you are in final gear, the clutch would not be required when enabling cc or am I missing something... Sorry for a newbie question.
ELITE-3.0-V6
  • Barnstaple north devon
  • The estate with a punch !!!
« Reply #9 on: 23 December 2007, 12:51:18 »
The switch turns off the cc if the clutch pedal is pressed or the brake pedal is pressed  8-)
« Reply #10 on: 23 December 2007, 13:31:26 »
Clutch switch is required for saftey in manuals, if you press the clutch it dis-engages the cruise. In a manual, no clutch switch - no cruise!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #11 on: 23 December 2007, 14:02:41 »
I fitted a Cruise Stalk to my 2.5td Manual CD, and It worked, clutch as well, the only thing it does'nt do is the Speed increment, ie push the far button once and it should increase a couple of MPH, and the resume speed memory does not work.
I assume would need to get it Tech 2'd for the complete operation?
Chris
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
« Reply #12 on: 23 December 2007, 18:11:11 »
Chris
possibly you have a faulty stalk?
regards
nathan
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
dpanic88
  • West Midlands
« Reply #13 on: 23 December 2007, 18:22:06 »
ah.. Many thanks for extra info, makes sence.
Is the clutch switch and easy install any one done it?
Xmas regards
Golfbuddy
  • Cornwall
« Reply #14 on: 23 December 2007, 19:22:09 »
Xmas regards
Yes they have. And here's how they did it.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1166374649
Page created in 0.032 seconds with 20 queries.
