Author Topic: Angle tightening  (Read 1331 times)
chrisdb
  • Chesterfield
Angle tightening
« on: 24 December 2007, 10:57:49 »
Does anyone know why some bolts are tightened by angle as opposed to torque, but also, why do they say for example, 30 then 30 rather than just 60?
It is not important but just curious.
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
Re: Angle tightening
« Reply #1 on: 24 December 2007, 11:02:22 »
Angle tightening is more accurate when you have bolts designed to stretch. The idea is that you have a low torque setting that establishes a starting point where everything is clamped together. As you angle tighten the bolt is stretching. Since the torque required to achieve a given amount of stretch is variable, depending on lubrication of the threads, etc, and angle is specified instead. If you turn a bolt through a given angle it will always wind itself into the hole by the same amount.
Bandit127
« Reply #2 on: 24 December 2007, 18:20:02 »
That was a quality reply, my knowledge is enriched! Thanks Kevin.
Jim
chrisdb
  • Chesterfield
« Reply #3 on: 24 December 2007, 20:11:28 »
Yes, thanks Kevin. I'm quite technical as that really explained it well.  :)
Page created in 0.166 seconds with 20 queries.
