Author Topic: Omega needs head gasket replacement ?  (Read 4346 times)
Ifield_Omega
  • Ifield, Crawley, West Sussex.
« on: 26 December 2007, 10:10:35 »
hi guys :)
hope your all having a nice xmas...and Happy new Yr  ;D
noticed on one of the posts a comment,
"Not sure why you have the impression that the 2.5 is unreliable, they should be as robust at the 3.0.  Often an oil cooler failure is mis diagnosed as a head gasket failure: that could be why lots of people are after relacement engines. "
this opened my eyes a bit as i have a recently " dead"  :( 1995 2.5 v6 omega cdx sitting outside my flat, local garage put a tester on it and told me it needs head gasket replaced or new engine, £600 + or £1000 if all goes well...i was gutted..only bought her in may this yr and paid £1200 cos in nice condition, i was tempted to spend the £600 and get her back on the rd,but my woman convinced me to buy another car and sell omega on as scrap or spares, I've held out on selling my lovely omega for a month but dont know how much longer I can hold out, lol..the problem is who can you trust and is it really head gasket ? Help !!  ( guys Im driving a citroen est now, so you can see why I need help please )
« Last Edit: 26 December 2007, 10:18:51 by Ifield_Omega »
Re: Omega needs head gasket replacement ?
« Reply #1 on: 26 December 2007, 10:28:07 »
We need some more info on the symptoms please
Is there sludge in the dipstick?
Mayo in the coolant tank?
What does it run like?
What sort of "tester" did they use? Compression tester, or emissions snifer in header tank?
While it happens, HG failure is rare and is commonly mis diagnosed, so it's definately worth checking out to be 100% sure.
Even if it is the head gaskets, it's not a difficult DIY job, and costs about £50 for a gasket set, + bits and bobs. £600 is OTT.
Ifield_Omega
« Reply #2 on: 26 December 2007, 10:48:05 »
Hi JamesV6CDX
thx very much for reply...
car still ran a few weeks ago, but a small pipe burst at the top back of engine and coolent was every where,I was having coolent probs and used radiator fix a few days before, gonna have a "look see" about questions as my memory is real bad
brb...
Ifield_Omega
« Reply #3 on: 26 December 2007, 11:09:25 »
ermm...battery flat..gonna buy some jumpers and get her running, but the oil on the stick is clear and no gloop on the cap or in the radiator reservoir..saying that she's been off rd for a few weeks  so could things have settled ? dont know what type of tester was used but I will find out asap..
« Reply #4 on: 26 December 2007, 12:06:27 »
It sounds like it could be as simple as a heater bypass valve failure, causing the coolant to over pressurise!
Flush out the coolant system, check out the HBV and see what happens! Could also be a blocked rad, ESPECIALLY if you have put radweld rubbish in there  :'(
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #5 on: 26 December 2007, 12:08:49 »
Water from the back will most likely be the Heater Bypass Valve...
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
Also with you using this radiator fix, its well worth flushing out the coolant and replacing with fresh once you change the HBV.
Humbugs...
« Reply #6 on: 26 December 2007, 12:14:13 »
He did say it was a pipe split...
Ifield_Omega
« Reply #7 on: 26 December 2007, 13:18:50 »
hi again  ;D
well bought a pucker powerpack..jumper..light..etc from halfords and me Omega started 1st time  ;D ..ran her up to temp about 90 deg still no gloop any where apart from the leak from the back and a water low warning but its defo' a pipe. garage who advised about the head gasket etc still closed but it is boxing day, thx for advice so far guys I will get hold of a HBV and flush out as advised. link how to do it usefull thx  8-)Will update as soon as this stuff done, dont know when yet as the handbag has a list lol...What ever happens guys thx for the help and thx for a good forum, dunno what we would do without you guys  :y
Have a good new yr
« Reply #8 on: 26 December 2007, 14:03:05 »
Remember that if you get air in the coolant system it WILL over pressurise............and a when a coling system cools down and the coolant contract.....it draws air IN
ELITE-3.0-V6
  • Barnstaple north devon
  • The estate with a punch !!!
« Reply #9 on: 26 December 2007, 14:32:47 »
sounds to me like the heater valve, if it was the oil cooler then the header tank would be full of oil...
Change that valve bud bring her back to life....  :y :y :y
Ifield_Omega
« Reply #10 on: 26 December 2007, 17:07:11 »
Thx 4 advice guys ....working on it  ;D
PaulW
« Reply #11 on: 26 December 2007, 18:36:22 »
It's been a long few days...
Humbugs...
ELITE-3.0-V6
« Reply #12 on: 27 December 2007, 10:46:16 »
could be such a simple fix, just think how gutted you would be if you scrapped it to then find out it might have just been a £50 valve....  >:(
« Reply #13 on: 27 December 2007, 14:32:44 »
£25 valve ;)
ELITE-3.0-V6
« Reply #14 on: 27 December 2007, 14:36:38 »
