Author Topic: Headlight question mini-facelift Projectors  (Read 2538 times)
jules
  • Edinburgh
  • Woke up this morning a post whore
« on: 29 December 2007, 18:02:46 »
Just went to drive to the inlaws and found I had no dipped beams.
Changed a bulb, and reseated the other and they're back on.
However, I noticed that on both lights the bulb/reflector assembly is loose, i can see a gap in the corner closest to the grill where it looks like it should be flushed up. I can move both lights around by hand and can tell that if I go over a bump they must be moving.
I did feel that they were not very bright previously and I have been flashed a few times.
My question is how should the bulb/reflector be attached and how do I go about repairing this ?
Many thanx
Jules
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
Re: Headlight question mini-facelift Projectors
« Reply #1 on: 29 December 2007, 18:05:51 »
Many thanx
Jules
Sounds like some ham fisted muppet has bust the adjusters.  A difficult repair if they have :(
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #2 on: 29 December 2007, 18:36:36 »
Absolutely - if the reflectors are loose then either one or both of the adjusters inside has broken
Almost impossible to repair so its new headlights I'm afraid :-/
IW
jules
  • Edinburgh
« Reply #3 on: 29 December 2007, 18:38:11 »
Oh bugger !
Anyone got any cheap ??
Pitchfork
« Reply #4 on: 29 December 2007, 18:51:54 »
A bit like Hen's teeth
Be wary of buying on e-bay - they quite often suffer from the same problem hence put up for auction in the hope that it will not be noticed
Even a supposedly specialist Omega Breaker has tried to sell me one that was damaged. I got my money back but not the cost of the return postage
There are new pattern headlamps on e-bay for under £100 the pair but steer clear of the black ones, they are illegal
IW
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 29 December 2007, 19:01:11 »
IW
is possible to repair done loads !!  ;)
jules
  • Edinburgh
« Reply #6 on: 29 December 2007, 19:05:51 »
IW
are you going to give me a clue ?
or do you want to play 20 questions ??
How is the bulb/reflector attached to the lens ?
markey mark
« Reply #7 on: 29 December 2007, 19:11:24 »
its quite involved bud you have to separate the clear lens from the black body !! once inside you will find the small black adjuster inner of the lamp has broken !! i have repaired mine and others with activated super glue !! drys very rapidly and very hard !! takes a few applications to make it strong but works bud !!
jim_c
  • 1999 2.5 cdx
« Reply #8 on: 29 December 2007, 19:21:24 »
can be repaired by removeing front lens covers and removeing lamp internals. Fiddly job but can be done
