Author Topic: Clutch pedal droop (is it bad)  (Read 1567 times)
davet
« on: 29 December 2007, 19:29:40 »
Hi everyone. Christmass eve and the clutch pedal goes to the floor and stays there, what has gone wrong (checked fluid, its on the low side but not empty) is it bad?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Clutch pedal droop (is it bad)
« Reply #1 on: 29 December 2007, 19:49:08 »
If you have a fluid leak then i would say it is a slave cylinder fault, but if not then the splines on the clutch cover plate may have collapsed and that means either way a box out job to check everything. :(
« Last Edit: 29 December 2007, 19:49:34 by ffcgary1 »
Jaguar XJ6
« Reply #2 on: 30 December 2007, 02:18:47 »
What's a clutch pedal?  :-/  :-/  :y  :y  :y
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #3 on: 30 December 2007, 11:42:49 »
It's the thing you rest your left foot on to stop it getting tired on long journeys.   ::)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #4 on: 30 December 2007, 11:46:43 »
Does this mean there is a reservoir somewhere to top up??  :-[
Trade club card holder
Code scanner available
« Reply #5 on: 30 December 2007, 12:06:46 »
Shared with the brake's reservoir.
alexandjen
  • The Silver Surfer
« Reply #6 on: 30 December 2007, 12:12:31 »
Ok thanks, but earlier in the year I changed my brake fluid so do I need to bleed the clutch circuit...........although the clutch seems to operate ok  :y
« Reply #7 on: 30 December 2007, 12:13:43 »
Could be a master cylinder problem, I guess. Have a look for signs of leakage. If none apparent, try screwing a bleed nipple into the master cylinder outlet instead of the pipe to slave cylinder. If pedal can be "pumped up" (a bit of "bleeding" may be necessary at the temporarily inserted bleed nipple) and become firm my guess is that the problem's at the slave end.
