Author Topic: Injectors issue help needed  (Read 1796 times)
nixoro
  • Hitchin, Herts
« on: 27 December 2007, 17:57:27 »
Took the car too and from London last night drove fine
Started the car this morning and all you can hear is clicking from under the fuel rail I'm guessing the injectors or the seals are fubarred
Was also pretty hard to get it started aswell once running the engine was shaking pretty violently so haven't used the car today deep joy.
Can anyone confirm whether this could be m my issue
Vx are getting me new seals for the Injectors and the seals for the fuel feed pipe and fuel return pipe going to try this option see how I get on.
Was soo close to selling it on before xmas
Merry Christmas too all :y
« Last Edit: 27 December 2007, 18:02:03 by nixoro »
Re: Injectors issue help needed
« Reply #1 on: 28 December 2007, 01:21:37 »
The injector seals themselves will only cure a fuel leak from the rail/injector connection, which you'd know about. :o
What makes you suspect the injectors? It is normal for them to rattle a little but they rarely fail.  :-/
Sure it's not the hydraulic tappets rattling?
nixoro
  • Hitchin, Herts
« Reply #2 on: 31 December 2007, 09:04:02 »
More than likely :(
« Reply #3 on: 31 December 2007, 11:32:54 »
Reading your other post.....I suspect you have now found the cause!
nixoro
  • Hitchin, Herts
« Reply #4 on: 31 December 2007, 11:49:31 »
Yep afraid so should've closed this thread off :y
