Author Topic: knackered car...gearbox ?  (Read 11343 times)
PaulyQ
  • Hartlepool
Re: knackered car...gearbox ?
« Reply #30 on: 21 December 2007, 16:57:20 »
So... instead of farting around I may just opt for the other gearbox.
Swapping a box over will be quicker than looking for a needle in a haystack I guess ?? :-?
« Reply #31 on: 21 December 2007, 17:28:41 »
If you can find a known good gearbox then that's what I'd do.
sassanach
  • trowbridge
« Reply #32 on: 21 December 2007, 20:25:20 »
how many miles has this box done?
PaulyQ
  • Hartlepool
« Reply #33 on: 21 December 2007, 21:50:27 »
If it's the original box it's done 100,000 or near as dammit - unknown history on the box(i.e. fluid changes etc)
« Last Edit: 21 December 2007, 21:51:02 by PaulyQ »
sassanach
  • trowbridge
« Reply #34 on: 24 December 2007, 14:06:37 »
hows this one progressing?
philayl
  • Wirral, Merseyide
« Reply #35 on: 24 December 2007, 14:58:11 »
I had exactly the same problem, same symptoms, afraid it was a goosed gearbox. Cost me £300 for a second hand gearbox off a known 38,000 miler, with 12 months warranty.
PaulyQ
  • Hartlepool
« Reply #36 on: 24 December 2007, 21:31:26 »
Will be after the new year when I get the motor back :(... will be a second hand box job for def by the looks of it... that will cost me £200, then the fitting is £300.
Hopefully back in the first week of new year to report back. I just the guy who is doing the motor changes the Thrust Washer(whatever that does) and is nice enough to clean out the selector switch as well.
PaulyQ
  • Hartlepool
« Reply #37 on: 28 December 2007, 23:07:35 »
Well, went to see the car today to see what was happening, guy has emptied the gearbox oil(as he was taking off the gearbox) and again it is black (after replacing it all last week), it looks like both reverse and forward clutch has burnt out (does that make sense to anybody??).
So.... new gearbox on Monday and hopefully my car back :)
sassanach
  • trowbridge
« Reply #38 on: 28 December 2007, 23:10:58 »
enlighten please there are 3 forward clutches and one reverse.
PaulyQ
  • Hartlepool
« Reply #39 on: 28 December 2007, 23:15:06 »
Enlighten please
Wish I could...Guy just mentioned just that mate.... forward and reverse clutch was knackered.
Now, call me cynical here, but the car won't engage into ANY gear so 3 forward clutches conking out is pretty much impossible (tried every which way to get the gears engaging - snow mode, sport etc... ), I am assuming it is just one of the forward gears and reverse.
Spoke to the guy who checked my filter and refilled last week and he said there was some muck and rubbish in the filters but nothing substantial, now I don't know the internals of a gearbox so don't know if something failed and decided to go for a float around the box and ruin things?
Question.... thrust washer..... what is it ... what does it do?
« Last Edit: 28 December 2007, 23:16:53 by PaulyQ »
sassanach
  • trowbridge
« Reply #40 on: 28 December 2007, 23:16:46 »
has this gearbox been dismantled?
PaulyQ
  • Hartlepool
« Reply #41 on: 28 December 2007, 23:19:01 »
gearbox not dismantled(just removed), and I'm not letting the mechanic get his hands on it either. I'm taking the old box with me.  :y
The reason it hasn't been dismantled is that I just need the car on the road and this chap is not a gear box specialist by any thinking.
« Last Edit: 28 December 2007, 23:20:36 by PaulyQ »
sassanach
  • trowbridge
« Reply #42 on: 28 December 2007, 23:21:06 »
i wish you were just around the corner anything to escape this boredom called christmas!!!
PaulyQ
  • Hartlepool
« Reply #43 on: 28 December 2007, 23:22:10 »
LMAO.
Do you think you know what it is?
Apart from a fooked box ?
Hey... think I'm about the only guy on here from around this neck of the woods.... full on Billy No Mates in the Omega world.  ;D
« Last Edit: 28 December 2007, 23:23:06 by PaulyQ »
sassanach
  • trowbridge
« Reply #44 on: 28 December 2007, 23:29:32 »
there is a strong possibility that you have a f@cked force motor in the front sump.this item controls the line pressure to ALL the clutches and band.however i have to admit at 100,000 miles you could simply have a knackered tranny.without a pressure test or a stripdown you will never know.
Pages: 1 2 [3] 4  All   Go Up
