Author Topic: newbie and question to ask  (Read 1331 times)
madders
« on: 31 December 2007, 16:29:23 »
hello guys and gals i have owened my omega for 8 months now not really any problems but week ago i went to birmingham from portsmouth area. when got there the car was covered in salt muck etc and the noise from the engine ba was like somehting was rubbing i put it down to the rubbsh from the road etc got back from brum no probs and got the car washed the noise still persited i have now since got under the bonnet and listerned to the engine when it revs the noise gets a little bit faster i put it down to the frount belt or pullys have given then a little wash and a spay from light gresse on pully working only seems to have sorted the noise. the only problem is i have is the engine seems very hot and a slight smell of oil burning is there. wonder if any one could have an idead before i run to vaxhall and looking at the engine bay the right side below the oil filler is was very hot indeed as i spilt my drink watter there and could here it fizzing on like somehting very hot.. as i said im a newbie and not very good with engines etc  the car is a facelift w reg 2.5 elite
ians
  • Reading
Re: newbie and question to ask
« Reply #1 on: 31 December 2007, 17:10:21 »
Hello and a big welcome :y :)
Firstly, sounds like you don't have the noise any more.  Great, but can you check when the cambelt/tensioners were last changed - that is most important and should have been done every 40k (or 4 years if sooner).    Worst case your noise is a tensioner about to go.
Next,  are you losing oil?  Try pulling a plug lead (front left is easiest) and have a look down there.   If you see oil it is likely that your cam cover gaskets have gone.  Have a look in the maintenance guide section for guides for replacement and also breather cleaning.
The exhaust manifold is very hot - suggest you don't touch it to find out ;)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #2 on: 31 December 2007, 20:13:59 »
welcome to the forum,
As has alreadt been said the service interval on a cambelt is 40,000 or 4 years, if these go then it is bye bye engine
the rubbing noise could have been a number of things, i would be inclined to check the idler pulley, this is mounted top left hand pulley as you re stood looking at the engine from the front.
if this goes then it can snap the aux belt, this can be ingested into the cambelt and the belt slips and then the valves make contact with the pistons.
Easiest way to check is to pop the aux belt off and spin the pully, is there freeplay or dies it feel very rough sounding, another check people do is to pop the belt off and then run the engine for a few mins to see if the noise goes away
hope that helps
madders
« Reply #3 on: 01 January 2008, 13:57:12 »
thanks for response guys the cam belt was changed with the pullys at vaxhall when i got the car 8 months ago ish the reason i got the car chaep. i am losing little bit of oil and i will check the plug to see if aany oil thanks for the help will update any more info as i find out
