Author Topic: 3.0 v 2.5 camcovers  (Read 1802 times)
MartinP
  • Dudley
    • BMW 320D
3.0 v 2.5 camcovers
« on: 01 January 2008, 16:35:24 »
Are they the same?
EPC shows different part numbers, is this only because they are in different engine sections or is there a physical difference?
As I understand the heads are the same with higher lift cams in the 3.0ltr
comments please
Re: 3.0 v 2.5 camcovers
« Reply #1 on: 01 January 2008, 16:37:28 »
Pretty certain heads are different, so probably covers different.
Thinking about it, 3.0 has different bore to 2.5, so heads will differ.
« Reply #2 on: 01 January 2008, 19:47:03 »
There the same......only difference on the heads is the dish in the combustion face....its a bit larger on the 3.0.
MutantCav
  • Gainsborough
« Reply #3 on: 01 January 2008, 20:14:57 »
The cam covers are the same, the 1mm difference on 3.0 cams dont affect the covers and neither will the slightly increased size bores...the heads size and shape themselves are the same...
MartinP
  • Dudley
    • BMW 320D
« Reply #4 on: 01 January 2008, 21:01:01 »
Thanks,
Any idea why they have different part numbers on EPC?
