Author Topic: Engine management light  (Read 1800 times)
Sir Gingerlot
  • Leicester
« on: 01 January 2008, 17:52:22 »
The orange light with the car and spanner is regularly coming on when I am driving the car. When I stop and switch off the engine, it seems to reset and then doe's not come on again for a little while. There seems to be nothing wrong with the car when driving it.
Will the management system be storing fault codes everytime this comes on and would it be advisable to get this checked by Tech 2?
Or as long as it resets each time should I just keep driving the car and not worry.  :D
Thanks
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Engine management light
« Reply #1 on: 01 January 2008, 17:55:33 »
Get it code read, if the light comes on then the fault code will be stored.
Is there any change in performance?
« Last Edit: 01 January 2008, 17:56:02 by alexandjen »
Trade club card holder
Code scanner available
Sir Gingerlot
  • Leicester
« Reply #2 on: 01 January 2008, 17:58:26 »
Not had the car long so unsure if performance is vastlt effected. Engine seems to rev fine up to red line and gearbox changes smoothly. The only thing I could comment on is that fuel consumption is a little low at around 24 mpg, but apparently these are a bit thirsty.
alexandjen
  • The Silver Surfer
« Reply #3 on: 01 January 2008, 18:00:26 »
Fuel consumption is very similar to mine  :y
« Reply #4 on: 01 January 2008, 21:08:05 »
May be worth a trip up the A46 to Marks_DTM_Calib so he can run a Tech2 on it....
Sir Gingerlot
  • Leicester
« Reply #5 on: 01 January 2008, 21:18:14 »
Sounds like a good idea. I will get in touch with him and see when its convenient.
