Author Topic: Should idle be smooth?  (Read 1904 times)
chrisdb
  • Chesterfield
« on: 03 January 2008, 16:14:12 »
On a 3.0 v6 should the idle be smooth at 650rpm or should the car vibrate noticably? When ECO is on the rpm drops to 500 and it is then smooth. It is not particuarly loud and it does not sound like timing is out...
I think I distantly remember a time when it was smooth, but it could my imagination. I have fitted new plugs twice - first was VX plugs and then later Irridium plugs, gapped correctly. Also fitted a complete set of HT leads.
« Last Edit: 03 January 2008, 16:15:41 by chrisdb »
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
Re: Should idle be smooth?
« Reply #1 on: 03 January 2008, 16:24:56 »
The vibration could be comming from the aircon compressor.
When ECO is pressed this turns off the compressor, hence the rpm drops.
« Reply #2 on: 03 January 2008, 16:26:49 »
650rpm sounds a tad high -
Check for air leaks.
« Reply #3 on: 03 January 2008, 16:27:36 »
Spot on with the compressor running.....
« Reply #4 on: 03 January 2008, 16:34:36 »
For a V6? Really? Mind idles at about 500rpm with compressor running, and 450 without...
« Reply #5 on: 03 January 2008, 16:40:52 »
The Elite idles at 500 rpm on gas, but it feels too low and a little lumpy.
On petrol the Elite idles at 650rpm....
ians
  • Reading
« Reply #6 on: 03 January 2008, 17:02:20 »
Think my V6's idle at c 500 with AC on , bit lower when off.  4 pots certainly idle higher.
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #7 on: 03 January 2008, 17:29:14 »
All the idle speeds mentioned should produce a smooth idle with no noticeable shaking of the engine. My 2.6l idles at exactly 500rpm,  (A/C on or off), and there is a slight vibration to be felt but it's barely noticeable. Nothing out of the ordinary.
Suppose I'll have to check that my compressor is running properly, although climate control is working fine, as far as I'm aware. HTH.
« Reply #8 on: 03 January 2008, 17:50:14 »
if this vibration is not lost after the engine warm up completely
you have problem I think..
