Author Topic: Location of Oil Level Sensor?  (Read 1601 times)
Sonic_Boom
  • Solihull near Birmingham
  • Omega Drift Master
« on: 04 January 2008, 17:11:12 »
I got "Oil Lack" come up on the trip computer so I checked the oil level to make sure I wasn't driving around on Oil Vapour but found the oil level was spot on.
So I assume that either the lead has fell off the sensor or the sensor has had it, but where abouts is it?
Cheers Rich
Re: Location of Oil Level Sensor?
« Reply #1 on: 04 January 2008, 17:14:17 »
Cheers Rich
Hi Rich,
The sensor itself is bolted to the bottom of the lower sump pan, which needs to be removed to gain access to the sensor.
Also check the plug and wiring, which is accessible on the drivers side of the engine, above the sump. No removal required.
Cheers
J
« Reply #2 on: 04 January 2008, 17:14:25 »
Cheers Rich
in the main ally part of the sump.
Edit
Doh! Iwas thinking of the plug!
« Last Edit: 04 January 2008, 17:15:15 by Andy_B »
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 04 January 2008, 18:47:19 »
A long uphill/downhill stretch of motorway or fast A road can flash the "low oil" message, check oil level 5 mins after the engine has stopped.
regards  :y
richard a
