Author Topic: How to flush 2.5 TD coolant??  (Read 1490 times)
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
« on: 04 January 2008, 12:46:17 »
I'm eager to flush the tractor and use the red anti-freeze but ive never done it before so im looking for some guidance before i make an ape of it.
How to drain it, how much coolant does it take, will i need to bleed it etc etc
thanks lads. :y :y
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
Re: How to flush 2.5 TD coolant??
« Reply #1 on: 04 January 2008, 13:52:14 »
i remember the tractor well for this....  :(
I belive there is a plug on the engine, right at the back on the drivers side??? someone will confirm.
Ohh yess and be prepared to get soaked!
kbou55
« Reply #2 on: 05 January 2008, 19:05:46 »
Anyone else with some more advice for me?
« Reply #3 on: 05 January 2008, 19:59:45 »
Rad drain tap on passenger side bottom of rad.
Engine drain plug, drivers side, about 2" above sump, towards rear.  15mm socket iirc, and yes, as Tunnie says, you will get wet!
