Author Topic: Heated front screen  (Read 6517 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Heated front screen
« Reply #15 on: 31 December 2007, 03:10:32 »
Got one of those on my Sapphire Cosworth , hate it, especially at night with on-coming headlights, they really shows up at night and do your eyes in, especially at high speed which is something you really don't need when your trying to read the road!
Daytime not too bad until you switch it on, distorts the vision until it’s fully warmed up.
Chris.
Paul M
  • Edinburgh
« Reply #16 on: 04 January 2008, 19:29:31 »
Personally I think they're great, it's one of my pet hates in almost all cars that the time your windscreen is most likely to be steamed up is when the car has been parked up overnight and it's cold outside, and that's the one time the heater is completely useless. I don't care so much about frost/ice, I'm quite willing to clear all the windows with a scraper, it's the condensation on the inside I hate. I refuse to wipe it with a cloth as it always leaves smears that are impossible to remove until the window is completely dry again. So I have to sit and wait for 10 minutes with the engine idling until the heater is warm enough to demist it... ah the wonders of modern technology ::)
I'm amazed there hasn't been some other technology developed to solve this issue, I remember back when I was a kid and long before I was old enough to drive (think it was 1991) my dad had a Ford that had a quickclear windscreen. 17 years later (god I'm getting old) and we're still sitting in brand new cars idling our engines to demist the windscreen using the heat from the engine :o
Chris.
I've never owned a car with one, but I have driven a few, and I found I quickly got used to it and after a while my brain just filters out the extra glare so I don't notice it. It would be nice if it were possible to have the same functionality without the wires being visible though.
On the latter point, I notice a similar thing on the rear window of my BMW. It has a very similar setup to the quickclear for the rear window heater, lots of very thin wires laminated between two layers of glass. Only difference is the wires are straight instead of wavy, and a few wires are used for the aerial so don't heat up. Normally you can't see them in the mirror, but after it's been switched on for a while you can see some distortion. It actually serves as a reminder to switch it off, but I've no idea why it does that as it's still visible after the glass has completely cleared
Oh and I've no idea why they decided to use such a system on the rear window... it costs £800 for a replacement should you need one :-/
« Reply #17 on: 04 January 2008, 21:09:30 »
....... it costs £800 for a replacement should you need one :-/
 :o  :o  :o  :o
alanfp
  • Chelmsford, Essex
« Reply #18 on: 04 January 2008, 22:42:19 »
Kevin,
If you want a heated seat (and I guess it would only be for the coldest couple of months of the year) get a heated seat cover that plugs into cig. lighter. I got mine from Woolworths for £10-15.  It works a treat. :)
It's not the neatest look, but like I said, it keeps you warm.  I generally switched it on for say 5-10 mins and that was sufficient to keep the cold at bay.  I found that I didn't like sitting on the 'leather-look' (ie plastic) material, so turned it over and sat on the nylon woven side.
Alan
zirk
  • Epping Forest
« Reply #19 on: 05 January 2008, 03:40:02 »
:question
« Last Edit: 05 January 2008, 03:45:42 by zirk »
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #20 on: 05 January 2008, 08:52:03 »
Love 'em.... really miss mine on my Cossie Scorpio :(...  it meant that I only had to defrost the works van...  the wifey just pressed a button! :)
I find the Omega takes bloody ages....  even with climate on...  how do folks go on with no A/C ???? :-/
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #21 on: 05 January 2008, 11:06:40 »
Going back about 25-30 years Volkwagen used to have a petrol heater in their cars (cant remember the model name) you could warm the car up before setting off..
They still do petrol heaters for the Camper vans
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #22 on: 05 January 2008, 18:25:05 »
That'll be Herbespacher,,,,  don't know if spelt right ;)  We had them on our Transits at BT, they warmed a tank of water too for the tap to wash the handies ::)...  many trucks / busses have them too, to prevent having the engine runnig... :y
DC
Minispud
  • Banbury, Oxfordshire
  • Ride hard with Passion
« Reply #23 on: 05 January 2008, 21:14:21 »
Unfortunatley Ford copyrighted/patented the heated front screen.
So only a car built under the Ford Motor Co. group can have one.
An easy way to wide up pompus Jag owners....'Nice re-shelled Mondeo you have there squire!'
 This is not quite right about the "Copyright Bit" I've had a Fine Wire Heated screens in the front and rear on my old Mini, I'm just trying to contact someone I know who might be able to help us out, with this little matter of heated front screens  :y
D.A.R.N.A Cycles.   Ride with Passion in your Heart
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #24 on: 06 January 2008, 08:18:00 »
If not copyright then pretty sure it's under licence...
DC
Page created in 0.024 seconds with 20 queries.
