Author Topic: fault code 69  (Read 1481 times)
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
fault code 69
« on: 02 January 2008, 16:39:42 »
intake air temp sensor voltage low,changed it with one thats good but still got the fault,anyone got any ideas???? :y
Re: fault code 69
« Reply #1 on: 02 January 2008, 16:44:05 »
Is it connected correctly.....i.e., is the correct plug on it and its not been confused with the one for the front multiram (the multiram one is the very last connector on that section of loom, the air temp sensor is the 3 from last)
Failing this, check the wires for damage and the large multiplug by the battery to make sure its fully inserted.
bobbertbear
  • perth
Re: fault code 69
« Reply #2 on: 02 January 2008, 16:47:12 »
only happened after i changed the engine,only difference was i left the wiring loom from the 96 car on the engine and the car is a 99,would this cause probs?
bobbertbear
  • perth
Re: fault code 69
« Reply #3 on: 06 January 2008, 16:36:32 »
hey you were right,had the wrong plug on it,changed it,eml went out,checked codes with acr handset and guess wot,no codes found,how great is that,thanks for the help. :D
