Author Topic: 2.5 and 2.6 V6 engines. Main changes?  (Read 2601 times)
6cylinderman
  • Co. Armagh, Northern Ireland.
« on: 06 January 2008, 21:23:44 »
Hi,
I'm looking at a couple of semi skimmed V6's with a view to buying.  The early facelift cars (99-01) seem to have a 2.5 engine and the later ones have a 2.6.
I'm sorry if this newbie question has been asked before, but what were the main changes made?  I assume the 2.6 is a development of the 2.5?  Are there any performance/economy adavntages with the newer engine and is it worth seeking out a 2.6 over a 2.5 or is it 6 to one half dozen the other?
TR
Re: 2.5 and 2.6 V6 engines. Main changes?
« Reply #1 on: 06 January 2008, 21:27:30 »
not much performance/economy wise between them.
2.6 is newer dbw unit, with coil per plug, no egr or sia, so arguably easier to work on.
Each has its pros and cons - I would say these even each other out.
« Reply #2 on: 06 January 2008, 21:29:02 »
2.6 has the "drive by wire" engine, which means the throttle is electronic controlled rather than the traditional cable.
The spark plug is linked to a coil back in the V, rather than the DIS pack mounted on the outside of the engine the 2.5.
Performace is about the same, maybe a fraction better with 2.6.
2.6 its easier to install cruise, just new store and tech2 enable.
2.6 bay is a lot neater lots of bits removed, i think??? no EGR?
« Reply #3 on: 06 January 2008, 21:31:17 »
Depends on your definition of easier - not everyone has a tech2 800yrds up the road ;)
2.5 (and 3.0) cruise really easy, bolt the bits in and it works :y
6cylinderman
« Reply #4 on: 06 January 2008, 21:37:13 »
Mmm.  Must look those acronyms up.  If it helps, I plan to install LPG in the car.  Also, it would be great if I could get some opinions on this Mig which has just come up for sale near me.  I hope this hyperlink works:
http://search.autotrader.co.uk/es-uk/www/cars/VAUXHALL+OMEGA/Ne-2-4-5-6-7-8-27-44-49-53-61-64-67-103-133-146,N-10-14-41-62-4294966436-4294966969/search.action
If it doesn't, let me know as I'd value your opinion on it.  The good thing is it's a manual!
« Reply #5 on: 06 January 2008, 21:38:27 »
low miles (if genuine - omegas wear well, so easy to clock), but pricey for CD
« Reply #6 on: 06 January 2008, 21:40:05 »
DBW - Drive by wire, no throttle cable
CPP - Coil per plug (ie, each plug has its own coil, no HT leads)
SAI - Secondary air injection (emissions thing)
EGR - Exhaust Gas Recirc (emissions, not needed on 2.6 due to lower compression ratio)
6cylinderman
« Reply #7 on: 06 January 2008, 21:44:04 »
Would £2500 be more like it?  I could get a Mig in the mainland but I have to budget £250 - £300 to bring it back to N. Ireland plus I'd be buying blind.  The choice here is rubbish.  A good manual V6 mig with less than 100k miles is like hens teeth over here!
« Reply #8 on: 06 January 2008, 21:46:34 »
2.5k is overpriced this side of the water in mainland market, but in your market it maybe better.
« Reply #9 on: 06 January 2008, 21:50:28 »
Sorry, didn't notice you were in NI  :-[
I have no idea on prices in your part of the world.
6cylinderman
« Reply #10 on: 06 January 2008, 21:58:28 »
Yes, for my sins!  I must've been a bad boy in a previous life!  Only kidding, it's not all bad.  There's some very nice scenic and twisty B roads near me that you boys would love!
Markjay
  • London
« Reply #11 on: 07 January 2008, 13:02:34 »
See also:
http://www.omegaowners.com/forum/YaBB.pl?num=1169337137
In addition, the 2.6/3.2 have inidividual coil packs, so no HT leads.
I'd say the 2.6/3.2 are much easier to work on due to having far less bits to worry about when working in the engine bay. But power-wise they are very similar in real life in spite of slightly higer BHP and torque figures claimed for the 2.6/3.2.
One more thing to note is that the 2.6/3.2 have lower compression ratios (10.0:1 instead of 10.8:1 on the older engines), so I am not sure what will happen if you try to fit a 2.6 head on a 2.5 engine...
Alas, no more Omegas....
bigdods
  • Brackley
« Reply #12 on: 07 January 2008, 13:20:47 »
That looks pricey for a CD. I recently bought a facelift 2000 70k Elite 3.0 and had to pay WAY more than I thought I should have as I urgently needed the car and wasnt bargaining from a position of strength. Cost me £3800 from a dealer (luckily with a warranty as I had £1000 of things went wrong in the first 2 months!). For me personally anything without the essentials would significantly reduce the price, by that I mean Leather, cruise, auto box
