Author Topic: Smoke from dipstick and oil filler cap?  (Read 4732 times)
Mike Bowden
  • Kingsclere, Hampshire
Re: Smoke from dipstick and oil filler cap?
« Reply #15 on: 07 January 2008, 18:49:22 »
Another update -
Had exhaust replaced - both rear and mid sections were blowing. However, not made much difference to the running.
It's still running pretty rough, and it seems to be quite rattly at idle - once the revs get up it runs better, but still not perfect. I've tried some Holts Piston Seal after a few people suggested it could be the piston rings wearing, but thats not made any difference  :(
It stalls quite easily too, especially when reversing with the wheel turning (extra load from the power steering?)
I changed the plugs when I put the piston seal in, just in case that would help, but no difference.
Any ideas?
Thanks!  :)
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #16 on: 07 January 2008, 20:03:37 »
I wonder if you have a vacuum leak somewhere?
As it is a 95 model, and I have the same engine in my Cavalier, does the breather system on your engine have the modification?  the modification is a large box fitted in the middle of the large pipe coming up from the crankcase to the rocker cover.
