Author Topic: omega 2.2 running bad  (Read 3844 times)
stu412t
« on: 02 January 2008, 18:05:02 »
hi i have a omega 2.2 gls 2001,last week it started running very bad like a missfire so took it to garage to find out what it was and was told to change coilpack which was done along with a service but still having problem but with no eml light.
any advice what to try next
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: omega 2.2 running bad
« Reply #1 on: 02 January 2008, 18:08:47 »
Remove coil pack and check plug wells for oil/water  :y
Trade club card holder
Code scanner available
stu412t
« Reply #2 on: 02 January 2008, 18:19:48 »
there is a small amount of oil but not much could this be shorting out
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 02 January 2008, 18:23:02 »
Yes, this would suggest that your cam covers are leaking.
I like red cars
alexandjen
  • The Silver Surfer
« Reply #4 on: 02 January 2008, 18:24:31 »
And that the cause of the leaky cam cover gasket is blocked breathers  :y
stu412t
« Reply #5 on: 02 January 2008, 18:27:45 »
i have checked all breathers and 1 was blocked but i have cleaned this and is clear now.
i will check oil around plugs and clean that and coil pack and try this to see if this is any better.
will reply later to tell you all results
alexandjen
  • The Silver Surfer
« Reply #6 on: 02 January 2008, 18:31:14 »
You will still need to change the cam cover gasket......use genuine Vx
The blocked breather would have caused the cam cover gasket to leak, did you clean all breathers including the vertical metal one bolted to the sump?
Edit: did you follow Auto Addicts' Maint Guide?
http://www.omegaowners.com/forum/YaBB.pl?num=1162397695
« Last Edit: 02 January 2008, 18:34:09 by alexandjen »
stu412t
« Reply #7 on: 02 January 2008, 21:53:19 »
just been out for another look.
no oil around plugs,all breathers clear,new coilpack,plugs,fuel filter,air filter,
revs seem to cut out at around 3000 rpm and pick up again at around 2000 rpm????iam lost
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 03 January 2008, 07:15:37 »
You need to have the codes read, where abouts are you?
Could be cam sensor failure.
I like red cars
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #9 on: 03 January 2008, 08:42:58 »
Can i just say, auto addicts maintenance guide is superb, i shall be following that one closely once the threat of snow has gone
Omega 2.6 V6 Elite in Shiny Black
« Reply #10 on: 03 January 2008, 09:38:25 »
When they did the diag work, did they do any actuator tests.....
.....coz they should have done!
It possible its a sticking EGR valve which would have shown up during actuator testing.
stu412t
« Reply #11 on: 03 January 2008, 13:27:31 »
SORTED AT LAST mass air flow meter £65 +VAT FROM EURO CAR PARTS
THANK YOU ALL FOR YOUR HELP
« Reply #12 on: 03 January 2008, 14:07:27 »
Which is something else that can be tested using the diag tools.....
rjay
  • Staffordshire
« Reply #13 on: 08 January 2008, 20:51:29 »
Hi - i am having the same problem on a 2.2 y22xe engine - 2000 cd model - replaced the cam gasket due to oil around the plugs and changed the airflow meter and still no change
I would be most interested to hear if anyone has another solution.
I don't know if this makes a difference but if i fill the car full of fuel and drive a distance down the road it will try to cut out loose power and missfire until the fuel level is below 3/4 of a tank???  - I am told this could be a dodgy fuel filter stopping the fuel flow.
Cheers Rjay
Grumpy
  • Manchester
« Reply #14 on: 08 January 2008, 21:15:14 »
Cheers Rjay
Seeing as your gasket leaked, did you also clean your breathers
and throttle body which is one cause for the gasket to leak?
See this 2.2L guide by Auto Addict. Pay particular attention to the
comments and picture at the end of the post.
I doubt the full fuel tank will cause cutting out. The only thing this
could possibly do, is maybe put fuel into your purge line to the
Throttle Body. But I would have to see how the lines lay to form
an opinion on this, plus any fluid traps built into the system.
Maybe someone who has delved deeper into the layout would
care to comment?
