Author Topic: nothing but trouble and expense, pile of junk  (Read 16692 times)
Re: nothing but trouble and expense, pile of junk
« Reply #15 on: 05 January 2008, 17:13:58 »
Decided on this for £85
Varta Silver Dynamic
http://www.varta-automotive.com/eng/content/microsites/microsite.html
more power than normal batteries as it has 750 cranking amps which is way more than a GM one or basic Exide, which means better at decharging and recharging, cold starts, and it stores more power inside when you leave it for longer periods of time.. hence actually starting!
infact it has the highest rating for the fitment of my car, the fitting code is 100 for a battery for an Omega Estate V6
this article is interesting reading
http://www.autoexpress.co.uk/products/products/210431/car_batteries.html
also comes with 5 year warranty
other batteries including GM come with 3 years, and sometimes 4
I find it odd that you quote extensive "facts" about the battery/capacity/cranking as if from knowledge/experience.. yet you did not know that a flat battery affects measured alternator output...
methinks you have been conned by snakeoil sellers ... GM on TC and save some money  :)
Wayne
« Reply #16 on: 05 January 2008, 17:18:50 »
well, i dont claim to know all the facts..
i had just read up on battery sources on the internet
anyway, i just cancelled my order as i needed to use my car tomorow
cant be asked to wait 3+ days for delivery
got a Varta Blue Dynamic Battery for £59 fitted from National Tyres in Oxford, being done tomorrow
and i get a 4 year warranty on it
cheers
PS: your right, i aint got a clue about alternators etc
thats WHY i`m on here asking!  :y
« Reply #17 on: 05 January 2008, 17:21:07 »
Also
if later will become necessary alternators dont need changing..There are simple parts in inside which can be serviced cheaply..
Abiton
« Reply #18 on: 05 January 2008, 17:21:43 »
Don't give up fella!
Rather than go to Kwik Fit and so on, I have heard through a good friend that the garage in Littleworth, just over the hill from you, is an 'honest' kind of place.
The alternator voltage may be a bit low (especially if it's still at that sort of level with the new battery); but it may be quite easy, and free, to fix, if it is. There's a "how to fix your alternator" (may not be the exact title) on the maintenance guide section that shows an internal contact that may simply need de-grotting.
I don't know the V6 engine at all, but if you want a second opinion on electrical or other stuff, I'm not far from you at all.
Cheers,
Pete
« Reply #19 on: 05 January 2008, 20:12:46 »
Wayne, as previously mentioned, get a TC card, you could have gone to your dealers today, and got a Go battery for much less....
Your car will be expensive to run if you keep using dealers and non-experieinced mechanics to maintain your (lovely) motor.
« Reply #20 on: 05 January 2008, 20:27:36 »
... and have a look at that positive battery terminal so your new battery doesn't go flat too. :y
Wayne
« Reply #21 on: 05 January 2008, 20:31:56 »
OKAY GUYS
so, tomorrow when i have the new sooper dooper battery fitted, do i then have the guy test the alternator again for a reading?
or go for a 45 minute drive and then test the alternator?
or do any of the above and then park it on my drive for 2 days and then get alternator tested?
« Last Edit: 05 January 2008, 20:32:39 by Wayne »
« Reply #22 on: 05 January 2008, 20:41:00 »
Personaly .. I'd go for option 2 ... drive to ensure battery that hopefully fully charged .. then alternator test
Minispud
  • Banbury, Oxfordshire
  • Ride hard with Passion
« Reply #23 on: 05 January 2008, 21:01:49 »
Hi Wayne,
 You could try "Trye-Ryte" they are in Marsh road, Cowley by the Oxford City Council works depot  :y What sort of music do you play, I'm into "Jean Michel Jarre"
« Last Edit: 05 January 2008, 21:04:13 by Minispud »
D.A.R.N.A Cycles.   Ride with Passion in your Heart
Martin_1962
« Reply #24 on: 06 January 2008, 10:21:32 »
Hi Wayne,
Look at his links - Bon Jovi tribute
BTW - seen the original years ago
ians
  • Reading
« Reply #25 on: 06 January 2008, 11:30:28 »
Hi Wayne,
I saw JMJ in the docklands (too) many years ago.  Good stuff
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #26 on: 06 January 2008, 11:38:05 »
Hi Wayne,
From what i can remember it was a good concert  :y
ians
  • Reading
« Reply #27 on: 06 January 2008, 11:42:46 »
Hi Wayne,
it was although memory is fading - must be best part of 20 years ago! oh shit..
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #28 on: 06 January 2008, 12:03:04 »
Hi Wayne,
it was although memory is fading - must be best part of 20 years ago! oh naff..
Destination Docklands ermmm... 1989 me thinks, was very young then ;D
« Last Edit: 06 January 2008, 12:04:21 by razzo »
Minispud
« Reply #29 on: 06 January 2008, 12:15:41 »
Hi Wayne,
 Yes I had a couple of tickets for that concert, but could not go  :'( :'( :'(, but I did get to see him just before Wembley was pulled down  :) :) and man was he good   ;):y :y
