Author Topic: 2.5 TD water pump failure???  (Read 1952 times)
kbou55
  • Tipperary, Ireland.
  • Peace, Through Superior Firepower
« on: 10 January 2008, 00:07:42 »
within eyesight of my house the engine temp red light came on so i switched off the engine an coasted home and let the beast cool down, some water came out the expansion cap but only a cup full id say.
i started it again and a few hours later and warmed it up, the engine started and was running fine with no bubbles or oil coming through the coolant with the cap off. i switched the cabin heat up full and no heat when there should be. the temp kept rising so i switched off the engine.
theres no coolant leaks so could it be the water pump impeller has shed a few blades and not circulating coolant or am i in bigger trouble?? :'( :-[ :'( :-[ :'( :-[ :'( :-[ :'( :-[
« Last Edit: 10 January 2008, 00:29:56 by kbou55 »
2002 Vectra 2.2 DTI Elite (for work)
2000 Zafira 1.8 Elegance (for the wife and kids)
2000 Honda Pan European ST1100 (for play)
Re: 2.5 TD water pump failure???
« Reply #1 on: 10 January 2008, 09:46:26 »
Its reasonably common for the water pump to throw blades on this lump......so start here.
« Reply #2 on: 10 January 2008, 12:29:00 »
And be aware, like most BMW engines, the heads are prone to cracking/warping through overheating, so don't let it go above 100C on the gauge...
kbou55
« Reply #3 on: 10 January 2008, 20:06:20 »
its gone to the local grease monkey to diagnose for me. It was hot for only a very short period, fingers crossed its ok or its back to the vectra again
kbou55
« Reply #4 on: 10 January 2008, 20:39:47 »
how should the said grease monkey check for a cracked/warped head on the bmw lump??????
thanks kb
« Reply #5 on: 10 January 2008, 20:46:44 »
thanks kb
Pressure test, or check for fumes in coolant...
kbou55
« Reply #6 on: 10 January 2008, 21:31:25 »
thanks kb
ill tell him to pressure test it, no fumes in the coolant so im half way there :y :y, any difficulty doing a pressure test on the lump???? or is it over complicated like it usually is
« Reply #7 on: 10 January 2008, 21:49:13 »
if not fumes in coolant, I'd simply see how it goes.....
kbou55
« Reply #8 on: 10 January 2008, 22:17:05 »
god bless the monkey, he said the water pump was shredded and a part of the impellor had lodged in the thermostat and damaged it aswell.  :-[ :-[
anyway, it could have been worse, many thanks for the support lads. the wife just didnt understand my pain :-* :-*
