Author Topic: Whats the HBV look like??  (Read 2366 times)
MutantCav
  • Gainsborough
« on: 10 January 2008, 17:14:58 »
I know roughly where it is...under the scuttle at the back of the engine as you look at the car...what does it look like and how do you take it out?
Jay w
  • Plymouth/Poole
  • omega gone
Re: Whats the HBV look like??
« Reply #1 on: 10 January 2008, 17:17:16 »
MutantCav
  • Gainsborough
« Reply #2 on: 10 January 2008, 17:25:55 »
Cheers :) Engine is already scuttle and half the engine free so should be able to see it quite easily in the morning :) Gonna keep it incase its needed for future...feel that it may also be advisable for me to take the oil cooler out at the same time :)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 10 January 2008, 17:58:32 »
why take the cooler out?
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 10 January 2008, 18:08:03 »
 because hes just bought a 95 elite with oil cooler gone !! :y
MutantCav
  • Gainsborough
« Reply #5 on: 10 January 2008, 18:16:45 »
Indeed, plus why not, handy to have out before I scrap the car :)
markey mark
« Reply #6 on: 10 January 2008, 18:18:01 »
 every car i strip i take it out !!  ::)
Markjay
  • London
« Reply #7 on: 10 January 2008, 18:45:07 »
..and that's what the new one looks like up close and personal:
Alas, no more Omegas....
MutantCav
  • Gainsborough
« Reply #8 on: 10 January 2008, 19:05:37 »
Cheers :) So what does the HBV do then?
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #9 on: 10 January 2008, 20:30:28 »
it controls the flow of water via a vac pipe, when you switch the heater on in the car the heater creates a vacumn this in turn opens the valve and allows water to flow into the heater matrix.
turn the heater off and the water flow is kept within the engine bay
hope that helps
MutantCav
  • Gainsborough
« Reply #10 on: 11 January 2008, 10:34:50 »
So if your car doesnt heat up when you put the heating on then its probably the HBV??? Not ever had that problem but useful to know :)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #11 on: 11 January 2008, 11:16:55 »
Possibly, or it could be the vac pipe has dropped off....
most common fault with HBV is that they leak
Markjay
  • London
« Reply #12 on: 11 January 2008, 20:07:41 »
most common fault with HBV is that they leak pour
 ;D
