Author Topic: Auto box fluid change  (Read 1774 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 11 January 2008, 09:49:35 »
Is there a how-to on this, just had a quick look and couldn't see one, i may be keeping my baby after all so i want to know everything there is to know about keeping it tip top....
Omega 2.6 V6 Elite in Shiny Black
ians
  • Reading
Re: Auto box fluid change
« Reply #1 on: 11 January 2008, 10:19:12 »
I'm not sure there is specifically but plenty of posts on it if you search.   Its in the book of lies too.
ians
  • Reading
« Reply #2 on: 11 January 2008, 11:16:04 »
Mark,
There is this though that will help filling it up.
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Cheers
Ian
« Reply #3 on: 11 January 2008, 11:19:24 »
Mark,
Cheers
Ian
Yes, remember creating that one.... :y
ians
  • Reading
« Reply #4 on: 11 January 2008, 11:31:20 »
quite entertaining trying to keep the hose I was using off the hot exhaust I seem to recall :(
You don't mention the changing gear bit while topping up Mark .  How necessary is that to get the level correct?
« Reply #5 on: 11 January 2008, 11:46:49 »
Not important of just topping up (as the galleries should already be full).....more essential when doing a change.
    • 530D M Sport, 330i Coupe
« Reply #6 on: 11 January 2008, 11:47:46 »
The guide is for topping up so in that case the box should already be primed. If you are changing the fluid completely (ie. dropping the sumps and cleaning / replacing the filter) then it is necesary to engage each gear to allow the fluid to flow.
EDIT... I wish I could type faster!
« Last Edit: 11 January 2008, 11:48:10 by VXL_V6 »
ians
  • Reading
« Reply #7 on: 11 January 2008, 11:55:38 »
thanks - I'll be checking it again when I next do an oil change.
..maybe worth a comment on the guide as I am sure many people use this when doing an ATF change..?
Markjay
  • London
« Reply #8 on: 11 January 2008, 20:09:10 »
Now that is a very good idea...  :)
Alas, no more Omegas....
Markjay
  • London
« Reply #9 on: 11 January 2008, 20:17:49 »
Also, a 500cc syringe with a long tube might help, both to empty the main sump before dropping it (to minimise spillage), and also for topping-up afterwards....
« Last Edit: 11 January 2008, 20:20:31 by markjay »
