Author Topic: swapping oils  (Read 2446 times)
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
swapping oils
« on: 11 January 2008, 11:22:56 »
can you move from one type of oil to another without flushing ,
td oil to semi synth or full synth :question
dieseldonicely
Jay w
  • Plymouth/Poole
  • omega gone
Re: swapping oils
« Reply #1 on: 11 January 2008, 11:53:19 »
I woulod say yes, but do the changes more frequently (3000k) in order to flush out the old stuff properly.
No point in going any higher spec that semi-synth
Re: swapping oils
« Reply #2 on: 11 January 2008, 19:09:42 »
I agree with JayW above, though a normal oil change for a TD should be around 3k, so initially change every 1k...
Markjay
  • London
Re: swapping oils
« Reply #3 on: 11 January 2008, 21:41:51 »
ALL modern engine oil are compatible with each other, so no harm will befall you if you mix them (though obviously for maximum protection you want to have as much of the higher-quality oil as possible...) .
So if you are running on say full-synth Mobil-1, and you discover that due to cam cover seals leak you are short of 1L, you will be better-off with topping-up using any semi-synth 10W-40 you can find rather than drive on until you manage to get some 'proper' Mobile-1....
Alas, no more Omegas....
Page created in 0.468 seconds with 20 queries.
