Author Topic: Auto box problem  (Read 12604 times)
Re: Auto box problem
« Reply #30 on: 09 January 2008, 21:09:35 »
[I believe the paperclip test does not show up gearbox faults? I'm in Essex.
Will display Engine ECU codes but it may be that it's something to do with the engine that is causing the box to throw a error.
correct
vegasgo
« Reply #31 on: 09 January 2008, 21:11:06 »
OK, will do the paperclip test tomorrow. Where can I find a page with the fault codes? Thanks.
« Reply #32 on: 09 January 2008, 21:36:08 »
few codes in the tech info section, else just post up and we'll tell you :)
vegasgo
« Reply #33 on: 10 January 2008, 12:15:04 »
OK, done the paperclip test - only getting code 73, which is the air flow sensor I think? What does that mean? Any relation to the gearbox?
« Reply #34 on: 10 January 2008, 12:44:35 »
I don't think that would cause a gearbox limp...
vegasgo
« Reply #35 on: 10 January 2008, 13:46:47 »
Well, I'm currently ading 2 litres of ATF through the breather pipe which is taking ages, I know its not the right way to do it but what the hell.
« Reply #36 on: 10 January 2008, 19:08:22 »
Trouble is, you'll never get level anywhere near close...
Is it leaking then?
vegasgo
« Reply #37 on: 10 January 2008, 20:33:42 »
No, its not leaking, I just wanted to add some oil and see what happens. Took 4 hours to add 2l through the breather pipe. Haven't test driven it yet but going through the gears no change apparent so far, though it now does take longer for AUTOMATIC GEARBOX to flash up. Will test drive it tomorrow, if its still playing up can anyone recommend a decent cliff to push it off?
To add add to my woes, got a letter from DVLA informing me the tax, which was due to expire 09/08, was in fact invalid as the previous owner's cheque did not cash and after three months of trying to get hold of the bastard without success, have now burdened me with it. I was going to send it back for a refund for the remaining months if no joy with the gearbox but now I have to pay back-dated road tax from 10/07 for a car that has barely been on the road since I bought it in November. More expense on a car I know I should never have bought in the first place, £1200 for the car, £600 for various automatic gearbox solutions that have not worked, £400 on insurance and now frigging road tax - that was my only hope of getting something back from.
« Reply #38 on: 10 January 2008, 20:49:23 »
Is the box slipping for about 10 - 20s before AUTOMATIC GEARBOX error?
vegasgo
« Reply #39 on: 10 January 2008, 20:54:52 »
I won't know until I test drive it.
« Reply #40 on: 10 January 2008, 20:58:53 »
but before you topped it up
vegasgo
« Reply #41 on: 10 January 2008, 20:59:51 »
No, it wasn't slipping at all, just always pulled away in 3/4th gear.
« Reply #42 on: 10 January 2008, 21:04:43 »
Even when just started?
vegasgo
« Reply #43 on: 10 January 2008, 21:07:17 »
Yes.
« Reply #44 on: 10 January 2008, 21:13:56 »
Yes.
Hmmm, sounds electrical then.
Does msg fire up before starting, or after starting...
Pages: 1 2 [3] 4  All   Go Up
