Author Topic: Grrrrrrrrrrrrr.It's packed up again.... 2.0ltr GLS  (Read 6113 times)
thegasgranny
« on: 09 January 2008, 21:53:57 »
Hello All,
Well, I thought I had cracked the cutting out problem after changing the crank sensor two weeks ago... but no. It broke down again (since changing the sensor) on the missus on a dual carriage way whilst on the way to pick up my 11 month old son from nursery.
I can't repeat exactly what she said to me on the phone, but it wasn't "hello dear, there seems to be a slight problem with the car"  :o
To cut a long story short, my mate got me to the car (she had managed to coast into a nearby lay-by) and guess what.. it started first time. Hmm.
I drove it about two miles before it coughed and spluttered but I managed to keep it going by going down the gears to almost bump it going again. Then it would clear and go like normal again before spluttering again. Again it cleared and I got to to my mates place where we got it in his garage.
The EML was not on. As a test we disconnected the cam sensor and it started - the EML was on as you would expect. We reconnected the sensor and again it started with no difficulty. EML went out.
I've been leaning towards a fuel problem from the word go because I have taken plugs out when it has packed up before (I was given it 600 miles ago and it's been doing this for the last 300!) and they have been as dry as a bone, even after quite a bit of cranking it at the side of the road. Also, we noticed, when it doesn't start, you don't hear the fuel pump prime, yet you do if it's going to start.
So with this in mind, my brother said he had something similar on his Vectra and it was caused by a faulty fuel relay. So I nicked his relays and tried the car again. It started but it was running 10mins earlier anyway. I decided to bite the bullet and take it for a test run and I made it out the garage before it packed up again. Arrggghhh!!
This "should" be a good motor - X reg, FSH, 62k, not abused, 2 owners but this is not good.
Anyone any suggestions? Oh, when it doesn't start, there appears to be no spark. Could the immobiliser be cutting the ignition and fuel pump???
At this rate, I will be getting rid as I can't afford it to keep breaking down.
Sorry about the long post. I'm going to sit in the lotus position and go Ummmmmmm for a bit.
Cheers.
TGG.
Craig_R
  • Watford
Re: Grrrrrrrrrrrrr.It's packed up again.... 2.0ltr GLS
« Reply #1 on: 09 January 2008, 22:26:25 »
Did or is the EML on ? If it is or has been since it broke on your misses read the codes by paper clipping it.
It soundsa little like what happened to me and it was my Cam Sensor.
Are the Revs limited to 4500 rmp ?
Oh also check the crank sensor is fitted bang on and correctly i heard of a guy who had problems had the crank sensor change and it was fine for alittle while then he kept having loads of problem he spent loads trying to find out what the problem was but after ages and ages he noticed the crank sensor was not fitted spot on so he refitted it and it sorted all his problems just an idea for you.
Craig
« Last Edit: 09 January 2008, 22:30:57 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
thegasgranny
« Reply #2 on: 09 January 2008, 22:38:57 »
Hello Sir CraigR,
Nope the EML is not on, and never has been other than when we did the test when we disconnected the cam sensor. It then went into limp mode as expected.
I've had the crank sensor changed to try and fix this, but it doesn't seemed to have made any difference.  :-/
Cheers
TGG.
Craig_R
  • Watford
« Reply #3 on: 09 January 2008, 22:46:52 »
check your spark plug holes to see if they have water or oil in them also you may need to check your Dissy pack and leads could be part of the problem. does it run rough when its going ?
Mod's
« Reply #4 on: 09 January 2008, 23:00:39 »
blocked fuel filter?
thegasgranny
« Reply #5 on: 09 January 2008, 23:15:43 »
Hi again Sir Craig,
There's been no water or oil in the plug holes and "when" it runs, it is really nice to drive. Thing is, I'm losing confidence in it, especially when the missus drives it the most usually with the boy in it.
Albitz: I did think about the fuel filter. There is a "wiff" of petrol coming from the rear too. My Dad (the previous owner) had a new fuel pump only a few thousand miles ago. Anyway, my mate has a filter in his garage so I might as well change that tomorrow together with the cam sensor which I already have. (I bought both cam and crank when I started having these problems) The thing is, I'm trying to eliminate one thing at a time, but it's a pain when I thought it was fixed as it had ran ok for two weeks (250 miles).
Thanks again for your help. Any more suggestions besides scrap it. :-?
Cheers.
TGG.
ians
  • Reading
« Reply #6 on: 10 January 2008, 11:07:12 »
These kind of intermittent problems are very difficult to diagnose - not helped by them re-occuring no doubt in the most inconvenient situations/weather :(
The thing is to be as systematic as possible - not changing a load of things at once.
There is a Schrader valve on the fuel rail (well there was on my 94 2L).
Its covered in a black plastic cap (like a big tyre valve cap).  If you remove that and depress the plunger you should get a squirt of fuel (be ready for it with a rag).
Persoanlly I think the intermittent nature of the problem rules out blocked fuel filter (no harm to change though) or burnt out leads - I think you'd get the symptoms all the time, or at least poor running.
Maybe worth getting the codes read again (not sure if you can paperclip on facelift 4 pot?)
There is a decent amount of fuel in the tank isn't there?
Martin_1962
« Reply #7 on: 10 January 2008, 11:31:18 »
I had this on a Carlton
It was a kink in a fuel hose near the tank - replaced the hose - fine afterwards.
Drove with molegrips clamping it open to get home!!
theowletman
  • Chester-le-street, Co. Durham
  • Mines a pint !
« Reply #8 on: 10 January 2008, 11:31:50 »
A long time ago I had a similar problem on my 3,0 Capri. It turned out to be a piece of paper in the fuel tank, probably from someone using paper as a funnel in the filler neck. When the fuel dropped to a certain level the paper was sucked onto the fuel pick up pipe by the action of the fuel pump blocking the fuel supply. After letting the car stand for a few minutes it would start again as the paper had floated away from the pick up pipe. I note that you have had a new pump fitted, it might be worth checking that the pick up pipe is clear, with no EML on it could be something as daft as this.
« Reply #9 on: 10 January 2008, 11:44:51 »
Interesting that the fuel pump doesn't run and there's no spark when the problem occurs. That tells me that either the ECU isn't detecting cranking (crank / cam / both sensors - eliminated), or that the switched ignition supply to the ECU, or the main engine relay, has packed up.
Might be worth changing the engine relay as well as the fuel pump (next to fuel pump relay, same pink colour).
thegasgranny
Grr.It's packed up again.. 2.0ltr GLS - FOR SALE
« Reply #10 on: 11 January 2008, 15:09:43 »
Hi Kevin,
Thanks for the reply.
I've changed both relay's with my brothers Vectra (2.0ltr Ecotech) which had a simular problem. He changed one of the relays and hey presto, his was fixed. Sadly, mine still isn't.
It's supposedly had a new fuel pump.
I can't keep throwing money at it, or being without it so my mate has lent me a fiesta for the time being.
I will be getting rid of the Omega now as I have no confidence in it. Shame because it 'should' be a good motor. Anyone interested in buying it? - 2 owners from new, genuine 62k FSH, new tyres all round, new CAM and CRANK sensors, fuel pump, fuel filter, ICV, timing belt changed at 45k, new disks and pads bla bla bla. I've got receipts for the lot. Sensible offers considered.
Cheers
TGG.
« Reply #11 on: 11 January 2008, 15:27:59 »
One question.....did you use a genuine crank sensor....
I have seen a couple of cases recently where the crank sensor does not sit properly in the mounting hole and can get an intermittent signal. It sometimes even raises a cam sensor incorrect signal error code.
thegasgranny
« Reply #12 on: 11 January 2008, 16:20:25 »
Yep, it was a genuine part, same as the cam sensor.
It was a right pig to do so I guess it's worth checking as it did run for two weeks after it was changed without any problems.
Cheers
TGG.
Craig_R
  • Watford
« Reply #13 on: 11 January 2008, 19:35:36 »
Craig
Check it again as i said above i know a guy who had a problem like this
Mod's
thegasgranny
« Reply #14 on: 11 January 2008, 23:02:23 »
Cheers Sir Craig.
I'll check it tomorrow. Have you any tips because it was a right pain to do originally?
Cheers.
TGG.
