Author Topic: Wet Carpet in Drivers Footwell  (Read 5252 times)
davlad22
  • Sunny Yorkshire
Re: Wet Carpet in Drivers Footwell
« Reply #15 on: 15 January 2008, 14:59:08 »
Oh, hope you get this sorted mate. Tis the worst thing, on a modern car as well! Our estate has a wet passenger side floor in the rear and still hasn't been sorted!
A dear aquaintance Mr McBurger suggested at one time ours could be a blockage in the drain hole from the air-con condensor (which lives near the heater matrix in the middle, behind the dash). Never did find out though.
The sound deadening stinks as well  :-[
DJ Pete
  • Chelmsford, Essex.
« Reply #16 on: 15 January 2008, 15:04:33 »
Thanks,
I've taken the sound deadening out and it is sat in my house, nice and dry, at the moment I've got a couple of bin liners under the carpet, to stop that getting wet!
The water is definately comeing down right in the corner where the A pillar meets the bulkhead, I just can't work out where from!
Pete.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #17 on: 15 January 2008, 21:54:08 »
Not the sun-roof drain then??
DJ Pete
« Reply #18 on: 15 January 2008, 21:56:00 »
Doesn't look like it, but I might try again if the rain ever stops and I get a chance to dry the car out!
Pitchfork
« Reply #19 on: 15 January 2008, 22:17:04 »
I'm in Leeds right now & it isn't raining (but I bet it is down south stil!)
JezInBrum
  • Birmingham
  • Built for comfort not speed
« Reply #20 on: 16 January 2008, 18:57:18 »
I have a similar problem myself. Have posted on here before but only got a few replies.
I have'nt done sunroof eubes tet but I did replace seal at base of windscreen.
It covers base of screen & top of scuttle panel.
It only cost about £11 or £12 from vx from memory. I am also one for the screen leaking theory. I notce that condensation trails start from the bottom right of the screen. But I know screens are a bugger to diagnose without some major stripping of trim
Jez
DJ Pete
« Reply #21 on: 16 January 2008, 19:56:45 »
Thanks Jez,
It's been raining here for tha last 3 days, so I haven't had a chance to do anything, but when I went to drive it tonight, I must have wiped around 5 litres of water from inside the windows!
I think I need to wait for some clear weather to dry it out before I look further!
This is so annoying!
Pete.
