Author Topic: Automatic transmission fault warning light  (Read 1767 times)
omegacdx
  • Worcestershire
« on: 16 January 2008, 18:55:45 »
Hi there
Today I noticed the message 'Automatic transmission fault' on the display as I drove along.
To change gear you had to do it manually.
It did the same thing several months ago, once you switch the engine off and restart it, all is back to normal, ie full automatic transmission and warning message disappears
Is this common? Is it something to worry about????? :-[
vauxnut1
  • Sunny Norfolk
  • Once driven - forever smitten !!
Re: Automatic transmission fault warning light
« Reply #1 on: 16 January 2008, 19:04:24 »
Mine does this every so often and I find that it does it on mine when I accelarate hard (especially in sports mode) then take my foot of accelerator so the gear change has a sudden jolt changing gear and then warning comes up and like you say you have to stop a restart car.
I never worried about it as its only in a blue moon it does it !!
I suppose I will when it dont go back to normal one day lol  :-/
VAUXHALL ...... ONCE DRIVEN FOREVER SMITTEN !!!!
omegacdx
  • Worcestershire
« Reply #2 on: 16 January 2008, 19:09:07 »
Mine did it today.....after a good flogging in sports mode.....after pulling over in a rest area, switching the engine off then back on it was fine
The first time it happened I had just left work. I noticed a jolt then the warning message appeared. That was months ago though
Hopefully it wont happen again!
« Reply #3 on: 16 January 2008, 19:50:02 »
I would recommend sorting the issue before it does further dmage to box
Martin_1962
« Reply #4 on: 16 January 2008, 19:57:15 »
It is the selector switch on hte side of the box
« Reply #5 on: 16 January 2008, 20:02:04 »
You might want to check fluid level and possibly the filter ... could be lack of oil pressure when you suddenly reduce drive, there's a "how to" in the guides for the oil check.
Oil change &  filter change is  just a little more work  :)
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Taxi_Driver
« Reply #6 on: 16 January 2008, 20:17:58 »
Agreed  :y
Ignoring autobox probs only make it worse in the end.......
Ive been driving autos for quite a few years......on one auto i ignored a burning atf smell after i'd been ragging it....it went a month like this.....then the box packed up totally.....a 4 year old car was scrapped......coz Ford wanted £1400 for a new autobox.
vauxnut1
  • Sunny Norfolk
« Reply #7 on: 16 January 2008, 20:29:06 »
Thanks for advice I shall check oil filter/oil (you never know!)
PaulyQ
  • Hartlepool
« Reply #8 on: 16 January 2008, 23:16:01 »
Also give the selector switch a good clean out as well. Fairly easy job to do.
Clear out any crud inside well, and then VERY lightly grease it with white grease to protect it.
