Author Topic: Air Conditioning  (Read 1928 times)
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
Air Conditioning
« on: 20 January 2008, 10:11:11 »
The Air Conditioning on my 2.6 seems to have stopped working. Can anyone tell what visible signs there are that the compressor is working ie: should the disc on the front be rotatong when engaged? If so how does this work? I have checked all of the fuses I can find, but all apear to be okay. I have also consulted my "Haynes" manual; and as usual the term "Chocolate Fire Guard" springs to mind. :-?
Cheers in advance
Re: Air Conditioning
« Reply #1 on: 20 January 2008, 11:37:06 »
if the system needs regassing then i dont think the compresser will work,because the gas (in its liquid form) acts as the lubricant for the compresser. i would start by getting someone to check if it needs regassing and then go on from there if you need to.
miggy
« Reply #2 on: 20 January 2008, 12:34:24 »
Cheers in advance
If checked and all is ok then try this..............this was my problem along with a few others on the forum..
http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #3 on: 20 January 2008, 12:55:32 »
Cheers in advance
The air con pully will rotate even if the compressor is not engaged. As said may need a re-gas. You can feel if the compressor is engaging through a change in vibration through the bodywork
« Reply #4 on: 20 January 2008, 13:07:51 »
Cheers in advance
Although the compressor on my 99 3.0 was engaged there was bugger all gas in the sysyem to do anything. I took it to an independant air con specialist last week for him to look at it. There was a whopping 200g(ish) in there, it should be nearer the kilo mark. Time will tell thoughhow long it stays put.
PxMetro
  • Stamford
    • 3.2 MV6 Estate
« Reply #5 on: 20 January 2008, 19:18:07 »
Not very good at working these forum things; but thanks all for the advice; at least I have a couple of things to go at.
Cheers
