Author Topic: Ride Height - please measure to compare  (Read 4642 times)
Martin_1962
« on: 22 September 2007, 18:16:48 »
I think my car is down at the back so I have measured the ride height.
From centre of wheel to top of arch the inside lip
Front average of 365mm
Rear average of 350mm
I would like to know what others have, including MV6 and also aftermarket springs (eg Brucie).
Need to know both to see how much mine is out and if I could get away with stiffer springs rather than OEM
hotel21
  • The Kingdom of Fife
Re: Ride Height - please measure to compare
« Reply #1 on: 22 September 2007, 19:06:27 »
My 1998 3.0 MV6 manual measures 368mm ave front and 333mm ave rear, wheel centre to arch lip.  The rears are direct Irmscher replacements and are supposed to be 30mm lowered from standard.
Dunno if that helps you Martin, but the car certainly handles better than it did.
    • 530D M Sport, 330i Coupe
« Reply #2 on: 22 September 2007, 19:06:39 »
Will go and check mine now, but does the LPG tank not make the rear sit a little lower than the norm?
Right
375 Rear, 370 Front
« Last Edit: 22 September 2007, 19:12:25 by VXL_V6 »
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 22 September 2007, 19:44:57 »
mine is the following
front  360
rear  380
« Reply #4 on: 22 September 2007, 19:58:32 »
Remember the shock, as well as springs, decide the ride height.
Martin_1962
« Reply #5 on: 22 September 2007, 20:50:08 »
So mine is quite down then, the front is not bad, but the rear is.
It is a bit bouncy, BTW the gas tank made little difference to height
But Brucies is 17mm lower, but that is MV6 so may be lower anyway.
Can anyone confirm ride height differences between MV6 and normal and what actually does it?
What I am planning is that if a lowered kit is no lower or barely any lower at the back I'll get and fit one along with assisted shocks.
« Reply #6 on: 22 September 2007, 21:38:18 »
iirc, MV6 is supposed to be about 30mm lower
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 22 September 2007, 23:37:58 »
Rear 375
Front 360
with new self levelling and springs on the rear only
Martin_1962
« Reply #8 on: 23 September 2007, 21:38:44 »
ANy more please?
justme
  • Shadowland
  • Testing by TB
« Reply #9 on: 23 September 2007, 21:47:34 »
Try measuring the ground clearance.
i.e. from the exhaust, the measurment is in the handbook. dont have an mv6
so cannot compare.
Test sig...
« Reply #10 on: 24 September 2007, 08:34:14 »
Martin, might be a daft question but.
I assume yours is on a flat surface with auto in neutral and hand brake off (chock the wheels)
Martin_1962
« Reply #11 on: 24 September 2007, 10:53:24 »
In park and brakes on shallow slope (1:100 roughly), if anything it would be higher not lower, as back is at the bottom.
No worse than when on the flat.
Nickbat
« Reply #12 on: 24 September 2007, 14:23:47 »
Martin,
Mine is 1 2002 2.6, with only 19k on the clock, so it's pretty much ex-showroom as far as suspension wear is concerned.
I checked the heights (handbrake off in P:
Both front and rear nearsides are 380
Both front and rear offsides are 375
The road has a slight camber, so I would say (downward to offside), so I would be looking at around 377.5 all round as an average.
Hope that helps! :)
Nick
Martin_1962
« Reply #13 on: 24 September 2007, 19:12:34 »
Sounds like my fronts are a bit tired and my rears are worn out
Dazzler
  • Haverhill, Suffolk
« Reply #14 on: 24 September 2007, 21:28:36 »
All that towing takes its toll in the end :(
Page created in 0.123 seconds with 20 queries.
