Author Topic: Traction control - how to install?  (Read 4081 times)
Re: Traction control - how to install?
« Reply #15 on: 21 January 2008, 21:01:45 »
Ok, so let's leave my engine, it's not possible to instal TC on 4 pots.
Not every V6 or TD had a TC so what about these? Is it just an software update or do the need new ECU?
So after 98 TC is using brakes?
only v6 had them. It was enabled on all of them.  Some Elites and plod MV6 were missing the button to disable it.
Post 98 do use rear brakes, this is not a stability control setup, purely applying light braking to spinning wheel.
RichB
  • Loughborough
« Reply #16 on: 21 January 2008, 21:34:57 »
Maybe you should consider buying a aftermarket traction control that cuts the injectors or ignition, something like the race logic traction control systems.
Probably be cheaper and easier to fit.
Cheers,
Richard
Page created in 0.008 seconds with 16 queries.
