Author Topic: Slight grinding when turning corner  (Read 1522 times)
dino
  • Leicester
« on: 23 January 2008, 15:13:09 »
Hi,
I was wondering if anyone knows what could cause a slight grinding noise when i turn a corner.  It is intermitant.  I have had new pads and discs at the front, the rear pads are fine but the rear discs have a small amount of surface corrosion on them around the edge.  I've had the tracking and balancing done aswell.
Many Thanks
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Slight grinding when turning corner
« Reply #1 on: 23 January 2008, 15:14:43 »
Have you got front mudflaps??
dino
  • Leicester
« Reply #2 on: 23 January 2008, 15:32:25 »
No front mudflaps.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 23 January 2008, 16:40:50 »
i get this from time to time, we have narrowed it down to disks touching pads.
mine does it when cornering hard, we thing the bearing has a small amount of movement and so it causes this to happen.
had the car on the ramps and nothing seems to be amiss and there is a tiny bit of freeplay, this is the only thing we can presume
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #4 on: 23 January 2008, 21:48:18 »
My 2.0l estate suffers this on braking when turning left, even gently. Still haven't sussed it out, but it doesn't seem to cause any serious problems. Damned annoying though!
I don't think it's the mud flaps, so will have to investigate discs, bearings, suspension struts, etc.
