Author Topic: Fuel Tank problem  (Read 1076 times)
holtender
  • Suffolk
    • 2.5 CDX Facelift
Fuel Tank problem
« on: 24 January 2008, 09:38:02 »
I have a problem getting my 2000 to fire up after removing the fuel tank, no fuel is reaching the injectors.
There  is about 2 gallons in the  tank and everything was fine before the tank was removed.
 Anyone have any suggestions?
« Last Edit: 24 January 2008, 09:40:16 by holtender »
Re: Fuel Tank problem
« Reply #1 on: 24 January 2008, 09:48:27 »
You could try removing the fuel feed line from the fuel rail, extending it with a length of fuel hose into a jerry can and turning the ignition on a couple of times to prime the pump. Then reconnect it and see if it goes.
