Author Topic: Changing cam cover gasket today  (Read 1896 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 24 January 2008, 12:17:28 »
I've started so i'll finish... ;)
Previously my mig had a head gasket replacement done at a garage.
Before it went in i noticed what looked like double glazing sealant oozed around the cam cover...
The garage that did the HG confirmed this and supposedly replaced the CC gasket too.
I have just removed the cam cover, the main gasket is in place BUT there are no O rings around the bolt holes.
The double glazing sealant is still in there in bits, hence there wouldn't have been a good seal to the face of the engine, no wonder its been pi$$ing oil out since i had it back... bloody cowboys...
I am going to do this job properly, incl cleaning breathers, with the knowledge i have obtained from this wonderful forum.
Omega 2.6 V6 Elite in Shiny Black
Re: Changing cam cover gasket today
« Reply #1 on: 24 January 2008, 12:18:49 »
Post up with any queries / progress :y
    • 530D M Sport, 330i Coupe
« Reply #2 on: 24 January 2008, 12:38:12 »
Just don't listen to me when I quote you the completely wrong parts!!!!
 ;D
mark.adams
  • Cambridgeshire
  • Happy
« Reply #3 on: 24 January 2008, 13:36:17 »
 ;D ;D ;D
Got gasket now and O rings...
Going to clean up cam cover before fitting.
Whereabouts should i use the sealant??
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 24 January 2008, 15:34:13 »
All done  :)
no longer leaking oil although its a little lumpy on idle since i reassembled, took it down the bypass for a blast but still the same.
I checked to make sure i hadn't left anything off and i haven't...
I removed and reseated the dis pack.
Any ideas?
« Reply #5 on: 24 January 2008, 15:58:17 »
lumpy idle is often air leak, so double check there. Then double check all breathers.
mark.adams
  • Cambridgeshire
  • Happy
« Reply #6 on: 24 January 2008, 16:44:21 »
where should i be looking for an air leak?
ians
  • Reading
« Reply #7 on: 24 January 2008, 16:48:10 »
On my 2.0 there was a whiteish vac line that ran round the back from throttle body to the EGR at the back of the cam cover.  it broke off at the EGR - took ages to find and cauased unstable idling (hunting).
Also check the breather hoses that connect to the camcover.
« Reply #8 on: 24 January 2008, 16:48:24 »
anywhere between maf and engine.
Page created in 0.025 seconds with 20 queries.
